Question about onboard DAC vs external DAC
  • invalid
    invalid Posts: 1,510
    VR3 wrote: »
    Correct, I'm just saying the connector your cable box uses is called an F type of I'm not mistaken.
    Bnc, 1.5m is the way!
    Too bad more manufacturers didn't use BNC connectors.
    VR3 Posts: 29,516
    Preach it man, I would love to convert all of my connections to bnc, neutrik speak on and neutrik power con
  • Dr_Wu
    Dr_Wu Posts: 356
    edited May 2024
    One of the things I like about Chord and Lumin is BNC connections. Got a RAL Prophecy digital coax from Brad with BNC on both ends.
    Post edited by Dr_Wu on
  • marvda1
    marvda1 Posts: 4,956
    If you only have rca connections, I hear it better to get your cables with bnc connectors and use bnc to rca adapters than to go straight rca connectors.
    Puritan PSM156
  • invalid
    marvda1 wrote: »
    That's correct, RCA can't be properly terminated to coax, but BNC can and the adapter does less harm than RCA directly terminated to coax.
  • marvda1
    I saved $300 on a new coaxial spdif cable with bnc connectors because people were only buying the rca ones.
    Puritan PSM156
    nooshinjohn Posts: 25,968
    marvda1 wrote: »
    I saved $300 on a new coaxial spdif cable with bnc connectors by switching my car insurance to Geico.
    Fixed!
  • mantis
    mantis Posts: 17,556
    treitz3 wrote: »
    I would advise against optical (in this situation only). Other than that? Take Paul's advice. It's solid.
    Curious what the situation is that Optical wouldn't be ideal?
    Dan
    treitz3 Posts: 20,068
    Between components.
  • CH46E
    CH46E Posts: 3,595
    treitz3 wrote: »
    Between components.
    For digital why would optic not be ideal? I'm not doubting you. Just want to understand.
    Long story short?
    Translation of signal.
  • bcwsrt
    bcwsrt Posts: 2,467
    I’m using optical (Toslink) from my CD player to my DAC with a DH Labs Glass Master cable. Toslink is my only option with my 30 year-old Sony ES CD player to bypass the internal DAC, but I have no complaints with it.
    I understand that Toslink is generally considered less desirable vs. coax or AES. If and when I upgrade to a dedicated streamer with a coax or AES connection, I might notice a difference between it and the CD player, but for now as I said earlier the CD player/Toslink combo is on par with my MacBook/USB combo going through the same DAC. And both are outrunning my vinyl setup
    Brian
    marvda1 wrote: »
    First off, you DO know I loves' ya' bro'. I do.
    As life marches on and we learn things? I am sorry but I can NOT agree with this statement. Like you? I didn't think that they amounted to a hill of beans. It's just an adapter, right? Connection in and connection out? No worries....
    That could not be further from the truth.
    My recent experience has shown and proven (to me) that your statement is not as simple as it sounds....although it will work in certain applications.
    Adapters bite donkey appendages. I didn't know it a short time ago. I damned sure do now.
  • Dr_Wu
    Dr_Wu Posts: 356
    I have a Chord Qutest DAC that only accepts BNC connectors. I used an AQ adapter (not cheap, and maybe not made any better than generic), and had no issues or humming that I could perceive. I did end up replacing the coax with its RCA connector with a RAL having BNCs on both ends. Just sayin' YMMV.
    As mentioned, they will work in certain applications. I have had that adapter in my rig for some time. When I got my Esoteric transport? I tried to hook the Mutec Master Clock up to it. I tried 4 different cables (All BNC/BNC with the adapter to RCA). I could never get the clock signal into the transport. Then a strange noise started in on the system (no matter the input on the pre) and the entire rig was down for a week.
    All that was removed was that adapter.
    The cable was replaced with the same exact cable, only this time with the proper terminations. Not only did the strange noise disappear? The sound improved as well, albeit slight, but it still improved.
  • CH46E
    CH46E Posts: 3,595
    edited July 2024
    Little update : I ended up running XLR out from Marantz udp7007 to Schitt Lokius (6 band eq that I love) then RCA AQ Columbia out to the Anthem tube pre then to the Krell amp. The Ifi dac is now only DAC'ing stream and Bluetooth. Kind of a waste I think. Later this week my new coax digital AQ cable should be here and I'll try the Ifi dac from the Marantz.
    Oh and the ifi is RCA out to to the Lokius also. Then to the Anthem. I didn't this way so I could basically use the Lokius as a switch for steaming and CDP. Works great.
