Best receiver for signature elite es60?
What would be best receiver for these speakers if I only use them without any other speakers and want to connect tv and PC, bluetooth would be great also. Are these Sony STR-DH190 and Yamaha R-S202D good enough? I would like to keep budget under 500$.
  • SeleniumFalcon
    SeleniumFalcon Posts: 4,396
    Hello,
    Welcome! In very broad general terms over the years Yamaha receivers seem to be a consistently better sounding audio company. With that said if you could find a Marantz receiver in the same or slightly more costly price range you would be pleased.
  • rooftop59
    rooftop59 Posts: 8,120
    So you want an integrated with a built in DAC for under $500? Here's a really good option: https://www.ebay.com/itm/256467473747?
    Or: https://www.ebay.com/itm/235494295205?epid=23054827241&
    Both Cambridge and arcam make music first products: I have owned multiple of both and keep coming back because of the sound quality and bang for your buck.
    Game Room 5.1.4:
    Bedroom 2.1
