Sub lost sync with the soundbar maginfi max after firmware update
Leon40
Hello there
the soundbar Magnifi Max cannot sync with subwoofer after firmware update to 136.
This soundbar was just purchased and open yesterday.
The sub was working in the beginning. but after firmware update the led on the back of sub just blinking all the time. long pressing on the sync button (in sub) doesnt help, nothing helping.
any idea?
thank you in advance.
any idea?
Hello,
Welcome to Polk's forum. I'll send this information to friend at Polk for recommendations. -
Here are his instructions:
1. Perform a power reset by unplugging the soundbar and sub for five minutes before plugging them back in.
2. Factory reset. Reset Magnifi soundbar (polkaudio.com)<https://support-uk.polkaudio.com/app/answers/detail/a_id/6565/~/reset-magnifi-soundbar#:~:text=If you experience issues with your Magnifi soundbar,this, all settings of the Bar are erased.>
thanks for suggestions.
i have tried the above, but without success.
any other ideas?
thank you all in advance -
If you contact Polk at 1-800-377-7655 and explain the situation they will replace your subwoofer.
