monitor 10 tweeter burned and crossover
amir
hi i have one of my veloved montitor 10 tweeter voice coil burned plus after check the crossover not sending signal to tweeter(when i put the other one in)
also both fuses fine
my gf connected them to pioneer **** amp that was causing problems
anyhow wandered what is the best way to go about it? repairing voice coil? new tweeter recommended? easy repair for the crossover or also getting one on ebay?
already tossed away this pioneer garbage
Thnaks for help
Thnaks for help
Answers
Hello,
Welcome to the Polk forum. Probably the first step is to determine which variation Monitor 10 you have. Can you post a photo of the front and back of the speaker with the grille cover removed? Also if you can supply a photo of the damaged crossover we can see what might need replacement. This speaker can easily be repaired fairly inexpensively. -
/67/k2fplmp2jhfe.jpg
cool thanks a lot
Those appear to be early Monitor 10s with Peerless tweeters, shame one is damaged. One thing to check is the metal tines on the fuse holders. Maybe take a little fine sandpaper or steel wool and clean the contacts that grip the fuse ends. Also, how did you check the fuses?
cool thanks
i just changed the fuses with the other monitor that works
and about the peerless any chace for repair of the voice coil? -
Buy a used Polk Peerless off eBay.
As for your method of connecting the speaker cable...that is NOT how to do it. -
Did you swap tweeters from one cabinet to the other ? That way you know it's the tweeter OR crossover OR issue with fuse holder tabs. Did you clean the fuse holder tabs, as stated above. After spray some contact cleaner on tabs & give em a try.Randy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
yes i changed the tweeters the problematoc one had burned voice coil for sure question if theres a way to fix it ?
Yes. Replace itRandy-Maine
by David WMG
THISBuy a used Polk Peerless off eBay.
Randy-Maine
by David WMG
While certainly possible it is not an easy task to replace a tweeter's voice coil. Usually the easiest method is to replace the complete tweeter. As @F1nut recommended find a Peerless on eBay, they are worth searching for.
For examining the crossover remove the four screws holding the input cup on the rear of the cabinet and pull it out. The crossover will be on the other side attached to the input cup. Usually damaged crossover components will be browned or blackened or detonated. A photo will help us diagnose. -
components look fine it might be like u said to sand paper where fuse is
If you did not ohm out the coil with a meter, then it could also be plate/magnet shifted.Don't take experimental gene therapies from known eugenicists. -
There is nothing obviously damaged on the crossover, however the fuse holder is a bit suspicious. The perfect tool would be a Dremel with a wire wheel attachment to get rid of the rust and oxidation.
how much ohm should it put normally? -
Usually around 6 to 8 ohms, if it is bad it will show zero. -
It should match the known good one's ohms.
And those are cast resistors.... as in they should be cast into file 13.Don't take experimental gene therapies from known eugenicists. -
This X2.
Back off those plastic terminals and use the holes for the loose wire. Safe bet you may have higher resistance with your current setup.
Cut those ends off and use fresh wire.
