monitor 10 tweeter burned and crossover
hi i have one of my veloved montitor 10 tweeter voice coil burned plus after check the crossover not sending signal to tweeter(when i put the other one in)
also both fuses fine
my gf connected them to pioneer **** amp that was causing problems
anyhow wandered what is the best way to go about it? repairing voice coil? new tweeter recommended? easy repair for the crossover or also getting one on ebay?
already tossed away this pioneer garbage
Thnaks for help
Answers
  • SeleniumFalcon
    SeleniumFalcon Posts: 4,353
    edited April 2024
    Hello,
    Welcome to the Polk forum. Probably the first step is to determine which variation Monitor 10 you have. Can you post a photo of the front and back of the speaker with the grille cover removed? Also if you can supply a photo of the damaged crossover we can see what might need replacement. This speaker can easily be repaired fairly inexpensively.
  • amir
    amir Posts: 8
    /67/k2fplmp2jhfe.jpg
  • amir
    amir Posts: 8
  • SeleniumFalcon
    Those appear to be early Monitor 10s with Peerless tweeters, shame one is damaged. One thing to check is the metal tines on the fuse holders. Maybe take a little fine sandpaper or steel wool and clean the contacts that grip the fuse ends. Also, how did you check the fuses?
  • amir
    amir Posts: 8
    cool thanks
    i just changed the fuses with the other monitor that works
    and about the peerless any chace for repair of the voice coil?
    F1nut Posts: 52,244
    edited April 2024
    Buy a used Polk Peerless off eBay.
    As for your method of connecting the speaker cable...that is NOT how to do it.
  • boston1450
    boston1450 Posts: 7,758
    Did you swap tweeters from one cabinet to the other ? That way you know it's the tweeter OR crossover OR issue with fuse holder tabs. Did you clean the fuse holder tabs, as stated above. After spray some contact cleaner on tabs & give em a try.
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • amir
    amir Posts: 8
    yes i changed the tweeters the problematoc one had burned voice coil for sure question if theres a way to fix it ?
  • boston1450
    Yes. Replace it
    Randy-Maine
    by David WMG
  • boston1450
    THIS
    Randy-Maine
    by David WMG
  • SeleniumFalcon
    While certainly possible it is not an easy task to replace a tweeter's voice coil. Usually the easiest method is to replace the complete tweeter. As @F1nut recommended find a Peerless on eBay, they are worth searching for.
    For examining the crossover remove the four screws holding the input cup on the rear of the cabinet and pull it out. The crossover will be on the other side attached to the input cup. Usually damaged crossover components will be browned or blackened or detonated. A photo will help us diagnose.
  • amir
    amir Posts: 8
    components look fine it might be like u said to sand paper where fuse is
    xschop Posts: 5,690
    amir wrote: »
    If you did not ohm out the coil with a meter, then it could also be plate/magnet shifted.
  • SeleniumFalcon
    There is nothing obviously damaged on the crossover, however the fuse holder is a bit suspicious. The perfect tool would be a Dremel with a wire wheel attachment to get rid of the rust and oxidation.
  • amir
    amir Posts: 8
    xschop wrote: »
    amir wrote: »
    how much ohm should it put normally?
    pitdogg2 Posts: 27,686
    amir wrote: »
    xschop wrote: »
    amir wrote: »
    Usually around 6 to 8 ohms, if it is bad it will show zero.
    xschop Posts: 5,690
    edited April 2024
    amir wrote: »
    xschop wrote: »
    amir wrote: »
    It should match the known good one's ohms.
    And those are cast resistors.... as in they should be cast into file 13.
  • gmcman
    gmcman Posts: 1,865
    This X2.
    Back off those plastic terminals and use the holes for the loose wire. Safe bet you may have higher resistance with your current setup.
    Cut those ends off and use fresh wire.
