Assembling a pair of Legends
2
    nooshinjohn Posts: 25,935
    Finally got a tracking number for the 4 woofers. The replacement tweeters are on the way as well
    Here is a look at the drivers for the L 600. The magnet structures are pretty large and heavy compared to Polk Audio products in the past. The baskets, however, are still made relatively thin, although they do have indentations in the structure to provide extra strength and support. I can easily see how some Dyna mat could improve the performance of the speakers by eliminating ringing within that structure. 0qh153j92egv.jpg
    edited April 2024
    This speaker has been prepped and ready for driver installation. This is a picture of the speaker before I begin doing that.ooclxxy3e3gn.jpg
    All drivers placed in position and ready to be secured. One thing about installing the drivers in the speakers is that they have to be oriented in such a way as to allow the pins on the beauty rings to clip in place. If you secure the driver in the wrong position, you will cover those holes and making it nearly impossible to fit the trim rings in place.
    The legend series uses different size connectors for positive and negative. This makes it idiot proof for making certain that you’ve got the right connections.
    One note about the tweeter around the outside of the bezel. It has a piece of 3M double-sided tape, which is used to secure the trim ring around it. I find using that tape to be redundant because the plate also has magnetic coupling, so just sliding into place in allowing the magnets to grip it makes it easier if you have to remove the driver later.7aa4e6q8jyag.jpg
    pitdogg2 Posts: 27,124
    This little piggie went to market....... :D:D
  • gyosa
    gyosa Posts: 770
    Kinda surprised Polk is using stamped steel baskets for speakers in this price point .
    How about the L800’s ?
    Bk
    PS Audio S300 , WiiM Ultra , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 48” - BEDROOM
    B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
    Parasound A21, Eversolo DMP-A8 , Kimber Kable 4vs , Ascend Acoustics ELX Ribbon Towers , Sony XBR-A8F 65” OLED - DEN , MAIN system
    Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO
    gyosa wrote: »
    Bk
    Stamped steel in there as well
    VR3 Posts: 29,457
    It's an engineering over correction... Lsim cast baskets were breaking so they reverted all the way to stamp steel.
    Kind of like when Janet Jackson revealed herself at the super bowl the next year was Paul McCartney playing piano for 15 minutes
  • muncybob
    muncybob Posts: 3,256
    So, not applying Dynamat to the baskets while they are open?
    Yep, my name really is Bob.
  • JayCee
    JayCee Posts: 1,509
    edited April 2024
    muncybob wrote: »
    I'd do so and will at some point when I go into my L800's. Surprisingly, John called his 1.2tl's fully modded at one point but didn't Dynamat. He later corrected his statement to say 'fully modded' but short of Dynamat 'cause he didn't have the time. Not sure where he lands re. this...?
    Speakers: Polk1.2tl's (Uber Mods) Pre/Amp/DAC: PS Audio PMG Signature Pre, BHK Signature 250, PMG Signature 512 Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" Power Conditioner: PS Audio P15 Power Plant Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬
    heiney9 Posts: 25,466
    gyosa wrote: »
    Bk
    Same drivers for all Legend speakers and I wouldn't be surprised if the same drivers are used in the Reserve series.
    Main differences are cabinet structure, material and more sophisticated x-overs L vs. R.
    **UPDATE on this project? Are they complete?
    edited May 2024
    heiney9 wrote: »
    They are complete minus the trim rings around the drivers and binding post plates. I do have the CAD drawings for for the rings but no way of putting them to use at the moment.
    edited June 2024
    I just received the trim rings for the L 600s. I had them 3-D printed based upon the plan provided to me by Polk Audio. They fit well... next steps are to prep and paint them in a satin black finish to match the baffles.
    Post edited by nooshinjohn on
    VR3 Posts: 29,457
    Awesome
    edited June 2024
    Raw 3D print…
    Almost ready for primer/paint.
    edited June 2024
    Ready for installation…
    Installed…
    VR3 Posts: 29,457
    Looks legit to me
    F1nut Posts: 51,858
    Good job!
    VR3 Posts: 29,457
    Looks factory! Who did the printing of your don't mind me asking
    VR3 Posts: 29,457
    Very cool
    msg Posts: 10,452
    Wow, John, those turned out nice! I'm impressed with how well you got the 3d printed rings cleaned up. Great looking finish.
    What did you do for the prep and finish process?
    edited June 2024
    msg wrote: »
    I am treating them the same way I would go about prepping a model airplane kit for paint. It took a bunch of hand sanding to get the shape right, I then switched to a finer grit, then applied a thin coat of primer to make sure the shape was correct. After that, a skim coat of modeler’s putty from Tamiya was applied to the entire ring. Once that dried fully, another sanding, then a finer grit, followed by final prime, inspection and paint.
    msg Posts: 10,452
    Good stuff. Your end result was well worth your efforts.
    What do you think?
    And are you planning on keeping these in house?
    I will say, I considered the L600s back when trying to decide which Legends to go with. Ultimately went with the L800s and a pair of L200s in case I didn't like the SDA.
    Have you listened to your L600s yet?
    msg wrote: »
    What do you think?
    No, I have not heard them yet, but I will give them a proper break-in when the time comes.i don’t expect them to come close to the L800’s, but in my room, anything is possible. It has been a fun project, which has me wondering why companies don’t offer a builder’s version of some of their products.
  • gmcman
    gmcman Posts: 1,851
    Fantastic work! Looks as good or better than factory...well done.
  • Milito
    Milito Posts: 2,003
    Great job John, they look great. Look forward to your impressions of them.
    edited June 2024
    Nice work not letting the cabinets go to waste.
    You might be surprised how close they sound to the L800's. Be sure to toe them in and about 10-12" off the rear wall to start.
    I love my L600's. They are superb. The synergy with my gear is off the charts. I was somewhat hesitant before I pulled the trigger.
