PSW-125, capacitor gassing off?
Replaced both IRF730 mosfets; went off the deep end and replaced all the parts on the PDC board (cause of mosfet failing). Amp is back up and running!
Great, that's good news.
@SeleniumFalcon I have THREE of the PSW110 that have the 600170 PCB I believe that all need troubleshooting. Can you please forward the schematic to me? Thanks!
Sent.
Received! Thank You!
SeleniumFalcon wrote: »I'll email you a schematic.
rorizzi1@hotmail.com
Envia para mim. Por favor
Thks -
Sent via email.
Hola Selenium falcón,podría tener una copia del PSW 125?
Agradecido de antemano. -
Hola Mithril oye esos IRF730 son del amplificador?
Lleva 2 iguales?
Y m podrías decir cuales lleva en la fuente?
Gracias. -
SeleniumFalcon wrote: »I'll send it.
Hello. Same issue with board 600170 rev5. Can you send schematic to mee too plz? -
Sent...
Hello SeleniumFalcon, may I have the schematic aswell?
Sent...
Just wanted to say, I admire how saavy the owners of these subwoofers are. I can't think of any other set of owners so able and willing to take apart and repair their speakers. It must be part of the questionnaire required before purchase.
Kudos to all psw owners!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Wondering if I could also get this schematic? TIA.
Sent...
SeleniumFalcon wrote: »Sent...
Would it be possible to get a copy of the schematic for the 600170 rev5 board? -
For the PSW125 ?
I have a PSW111 but I believe the amp module is the same for both of the subwoofer as my circuit board is labeled as 600170 rev5 board.
I've sent the available schematic drawings.
SeleniumFalcon wrote: »I've sent the available schematic drawings.
I'm having this issue as well. Wondering if you could send the schematic? -
Information sent.
Hello Selenium falcón, could you give me a copy of PSW 125?
I need value R77 on power board, is broken
Sent via email..
My R77 is marked 3011 which I believe is a 3.01kΩ resistor.
Hi @SeleniumFalcon can you send me schematic for PSW125, board CANADA BASH 600170 REV:6 or even previous rev may help me. Large film cap next to a potentiometer failed and melted the pot and I think a jumper?
Schematic sent...
Hello Selenium ... could you send schematics for CANADA BASH 600170 REV:6 ... would appreciate it much.
Hello,
Schematic sent.
