12AX7 Tubes
Faustin
Continuing the purge. Here are 12AX7 tubes that I have available. They all tested strong. Let me know if you need more info or pictures. PayPal ff. Pricing does not include shipping. I will be going through 12AU7's and the variants next.
2) Amperex 12AX7A. Marked W Germany. Flash on start up................$75 for the pair
2) RCA 12AX7A Marked Grt. Britain with a foil stamp...........................$65 for the pair
2)Sylvania 12AX7A..............................................................................$ 25 for the pair
2) RCA 12AX7A marked Grt. Britain.....................................................$ 60 for the pair
2) Tung Sol 12AX7A labelled for Magnavox..........................................$ 25 for the pair
2) National Electronics 12AX7A Marked Made in England with foil stamp...$ 65 for the pair
2) Sylvania 12AX7 Black Plate................................................................$ 25 for the pair
3) GE 12AX7 Date code CH - I believe 1973. NOS..................................$ 20 each
3) Sylvania 12AX7 Blk Plate D getter date code 413 - 1964....................$ 15 each
4) RCA 12AX7 Tall blk plates, 2 are marked 1958, I believe they all are.....$ 15 each
1) RCA 12AX7 Tall gray plates....................................................................$ 10
7) RCA 12AX7A short gray plates all with date code FA - 1973 NOS...........$ 30 each
2) RCA 12AX7 Long blk plate - label gone................................................$ 15 for the pair
5) Sylvania 12AX7A with date code ff NOS................................................$ 25 each
3) Sylvania 12AX7A with date code fi NOS.................................................$25 each
ZOMG! @pitdogg2
What Ivan said
I’ll take the following:
2) RCA 12AX7A long blk plate -label gone $15/pair
2) RCA 12AX7A tall blk plate - 2 marked 1958, I believe all are - $15 each. ( It appears pitdogg2 took 2, I’d like the other two).
Thanks -
Right now the 2) RCA 12AX7 Grt Britain , 2) Tung Sol Magnavox, 2) RCA 12AX7A long blk plate label gone, all 4) RCA 12AX7A 1958 are spoken for.
Got any older 5751s you want to part with??Yep, my name really is Bob.
Rogue Audio Conus Magnum iii Dark, Denon DP1200 w/Shure V15 Type V and Jico SAS stylus, Marantz UD7007, Polk L600, Rythmik L12 sub. -
I just sold a bunch of 5751's last night. I wish you would have sent me pm. I probably had some that would have been of interest to you.
All of the above listed 12AX7's are SOLD.
Tag me when you post your 12AU7's, please.2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-59L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
