12AX7 Tubes
Continuing the purge. Here are 12AX7 tubes that I have available. They all tested strong. Let me know if you need more info or pictures. PayPal ff. Pricing does not include shipping. I will be going through 12AU7's and the variants next.
2) Amperex 12AX7A. Marked W Germany. Flash on start up................$75 for the pair
2) RCA 12AX7A Marked Grt. Britain with a foil stamp...........................$65 for the pair
2)Sylvania 12AX7A..............................................................................$ 25 for the pair
2) RCA 12AX7A marked Grt. Britain.....................................................$ 60 for the pair
2) Tung Sol 12AX7A labelled for Magnavox..........................................$ 25 for the pair
2) National Electronics 12AX7A Marked Made in England with foil stamp...$ 65 for the pair
2) Sylvania 12AX7 Black Plate................................................................$ 25 for the pair
3) GE 12AX7 Date code CH - I believe 1973. NOS..................................$ 20 each
3) Sylvania 12AX7 Blk Plate D getter date code 413 - 1964....................$ 15 each
4) RCA 12AX7 Tall blk plates, 2 are marked 1958, I believe they all are.....$ 15 each
1) RCA 12AX7 Tall gray plates....................................................................$ 10
7) RCA 12AX7A short gray plates all with date code FA - 1973 NOS...........$ 30 each
2) RCA 12AX7 Long blk plate - label gone................................................$ 15 for the pair
5) Sylvania 12AX7A with date code ff NOS................................................$ 25 each
3) Sylvania 12AX7A with date code fi NOS.................................................$25 each
    Clipdat Posts: 13,101
    pitdogg2 Posts: 27,776
    edited February 2024
    Yes I'll be giving these a good look, I know where Bruce lives :D
    For now I call did on the Tung Sols
    2 of these RCA 12AX7 Tall blk plates, 2 are marked 1958, I believe they all are.....$ 15 each
  • Faustin
    Faustin Posts: 1,151
    What Ivan said :)
    Toolfan66 Posts: 18,369
  • dromunds
    dromunds Posts: 10,164
    I’ll take the following:
    2) RCA 12AX7A long blk plate -label gone $15/pair
    2) RCA 12AX7A tall blk plate - 2 marked 1958, I believe all are - $15 each. ( It appears pitdogg2 took 2, I’d like the other two).
  • Faustin
    Right now the 2) RCA 12AX7 Grt Britain , 2) Tung Sol Magnavox, 2) RCA 12AX7A long blk plate label gone, all 4) RCA 12AX7A 1958 are spoken for.
  • muncybob
    muncybob Posts: 3,302
    Got any older 5751s you want to part with??
    Yep, my name really is Bob.
  • Faustin
    muncybob wrote: »
    I just sold a bunch of 5751's last night. I wish you would have sent me pm. I probably had some that would have been of interest to you.
  • Faustin
    All of the above listed 12AX7's are SOLD.
  • xsmi
    xsmi Posts: 1,812
    Tag me when you post your 12AU7's, please.
    2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-59L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
