Problems with grounding? Not anymore!
ALL212
Checks all the boxes and punches way above its weight.
http://www.mableaudio.com/en/productview.asp?sid=6036
Aaron
Enabler Extraordinaire
100 dollars for a box of rocks- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
The charcoal "filter" should help with the smell.Yep, my name really is Bob.
Parasound HCA1500A(indoor sound) and HCA1000(outdoor sound), Dynaco PAS4, Denon DP1200 w/Shure V15 Type V and Jico SAS stylus, Marantz UD7007, Polk L600, Rythmik L12 sub. -
Does snake oil have a smell?
Does it come with an operator's manual? How far deep in the ground should you bury it?George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
Gardenstater wrote: »Does it come with an operator's manual? How far deep in the ground should you bury it?
It’s the desktop model of grounding! No need to bury it. Just fill it and snap on the clip.
Easy pesy…!
Aaron
Enabler Extraordinaire -
Is that considered a "floating" ground?
I'll tell you one thing: Those won't work in England that way. You would have to fill that box with dirt because they have "earth" instead of "ground".
Dude. It's got a 4N Cooper board!
Cool.
I guess they don't include rocks 'n' grit 'n' sand 'n' stuff to put in it?
Can we use Shakti Stones?
https://www.shakti-innovations.com/
Does Geoff Kait still sell Brilliant Pebbles?
https://www.machinadynamica.com/machina31.htm
His website's lookin' pretty threadbare.
SeleniumFalcon wrote: »Does snake oil have a smell?
Yes.
It smells almost exactly like burning money.
How are airplanes earthed in England? -
I would say "flaps", but I don't want to get banned! -
This grounding system takes advantage of cold fusion (the 99.99% pure copper wire is fused to the cold water pipe), quantum portal tunneling to achieve a never before level of music enhancement to bring you directly into the realm of audio perfection.
The use of the word quantum increased the price 1000%
I would be on board if the original item was cryo treated personally- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I use the wife's house plants. I think it helps growth as it gets bigger every year!
Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
SCompRacer wrote: »I use the wife's house plants. I think it helps growth as it gets bigger every year!
It's all those audio electrons!
Remember, all takeoffs are optional, but all landings are mandatory.
I have a hankerin' for some croissants all the sudden.Don't take experimental gene therapies from known eugenicists.
