Problems with grounding? Not anymore!
Checks all the boxes and punches way above its weight.
http://www.mableaudio.com/en/productview.asp?sid=6036
Aaron
Enabler Extraordinaire
    VR3 Posts: 29,759
    100 dollars for a box of rocks
    xschop Posts: 5,917
    VR3 wrote: »
    That'd be a steal for Hunter.
  • muncybob
    muncybob Posts: 3,350
    The charcoal "filter" should help with the smell.
    Yep, my name really is Bob.
    Rogue Audio Conus Magnum iii Dark, Denon DP1200 w/Shure V15 Type V and Jico SAS stylus, Marantz UD7007, Polk L600, Rythmik L12 sub.
  • SeleniumFalcon
    Does snake oil have a smell?
  • Gardenstater
    Does it come with an operator's manual? How far deep in the ground should you bury it?
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • ALL212
    ALL212 Posts: 1,690
    It’s the desktop model of grounding! No need to bury it. Just fill it and snap on the clip.
    Easy pesy…!
    Aaron
  • skipshot12
    skipshot12 Posts: 2,171
    pitdogg2 Posts: 27,914
    Is that considered a "floating" ground?
    Viking64 Posts: 7,830
    I'll tell you one thing: Those won't work in England that way. You would have to fill that box with dirt because they have "earth" instead of "ground".
    mhardy6647 Posts: 35,562
    edited February 2024
    Dude. It's got a 4N Cooper board!
    Cool.
    I guess they don't include rocks 'n' grit 'n' sand 'n' stuff to put in it?
    Can we use Shakti Stones?
    https://www.shakti-innovations.com/
    Does Geoff Kait still sell Brilliant Pebbles?
    https://www.machinadynamica.com/machina31.htm
    His website's lookin' pretty threadbare.
  • tonyp063
    tonyp063 Posts: 1,157
    Yes.
    It smells almost exactly like burning money.
    xschop Posts: 5,917
  • invalid
    invalid Posts: 1,560
    Viking64 wrote: »
    How are airplanes earthed in England?
    invalid wrote: »
    Viking64 wrote: »
    I would say "flaps", but I don't want to get banned!
  • SeleniumFalcon
    This grounding system takes advantage of cold fusion (the 99.99% pure copper wire is fused to the cold water pipe), quantum portal tunneling to achieve a never before level of music enhancement to bring you directly into the realm of audio perfection.
    VR3 Posts: 29,759
    The use of the word quantum increased the price 1000%
    I would be on board if the original item was cryo treated personally
    SCompRacer Posts: 9,405
    I use the wife's house plants. I think it helps growth as it gets bigger every year! :D
    SCompRacer wrote: »
    It's all those audio electrons!
    invalid wrote: »
    Viking64 wrote: »
    Remember, all takeoffs are optional, but all landings are mandatory.
    B)
    xschop Posts: 5,917
    I have a hankerin' for some croissants all the sudden.
