Polk omni SB1+ flashing blue and white light?
Hi, whenever I turn on my SB1+ soundbar, this happens. I've tried some basic trouble-shooting steps but nothing seems to help. Any ideas on how to clear this error?
    F1nut Posts: 52,241
    Try calling Polk customer service for help as they do not monitor the site.
  • SeleniumFalcon
    I'll check with a friend at Polk, but in the meanwhile calling 1-800-377-7655 is a good idea.
  • SeleniumFalcon
    Here is an explanation of the LED's function:
    A single red LED means the unit is in the "standby" mode.
    A single orange LED means "source 1" is a PCM device
    A single green LED means "source 1" is a Dolby Digital device
    Two orange LEDs mean "source 2" is selected
    A single blue LED means "source 2" is a Bluetooth device, blinking blue LEDs mean the device is not connected.
    When white LEDs are blinking "mute" is engaged, "volume", "voice" and "bass" will have white LEDs when being activated.
  • nicoargca
    Thank you guys, appreciate the input but there is no reference anywhere on what this combinations of white and blue blinking is. I will try to play with the remote, see if perhaps it is muted, but I've even tried to reset the bar by long pressing 'wifi' button and nothing happens.
  • SeleniumFalcon
    You might want to unplug the power cord, leave it unconnected for a few minutes, then reconnect. Sometimes you have to do this several times to reset the circuitry.
  • nicoargca
    Anybody with other insights? I still have the same issue.
    Has anybody tried to take this soundbar apart? Any parts that are replaceable?
