XS-Dreadnaught
xschop
xschop Posts: 5,737
edited February 2024 in DIY, Mods & Tweaks
Got the toroidal on the work bench for measurements. It comes with a powder-coated steel top-plate and a steel thru bolt. I will have to machine a custom alloy centering spud to mount it. There will be no ferrous metals in this case. Good news I'll only have to machine out it's billet housing by @ 0.100 to clear the factory out-of-round windings, but mainly the output wires do make it's major OD 6.7" at that location....
«1345
    msg Posts: 10,620
    <watching>
    Viking64 Posts: 7,767
    msg wrote: »
    <watching>
    Perv.
    nooshinjohn Posts: 26,102
    I would give at least a half-inch all the way around for wire clearance. The sharp bend angle would give me some concerns.
    xschop Posts: 5,737
    The wires exit the toroid upwards.Taking off too much wall may ruin one of the design goals for the case to be RFI proof.
    Toolfan66 Posts: 18,361
    msg wrote: »
    <watching>
    xschop Posts: 5,737
    Settled on my final design. Will have zero exposed fasteners and use only one bolt and tensioning nut. B)
    xschop Posts: 5,737
    Powder-coated clamp-down plate is outaheah...
    xschop Posts: 5,737
    Will machine an alloy centering spud/ lock nut combo next...
    xschop Posts: 5,737
    xschop Posts: 5,737
    A little more ID than I had planned to remove. Walls should still be 0.350 thick when done...
    VR3 Posts: 29,695
    Should be plenty thick
    VR3 wrote: »
    Overkill, In a good way.. B)
    xschop Posts: 5,737
    The top plate surely won't let any RFI penetrate lol....
    xschop Posts: 5,737
    Last pass at 6.725 ID. My torroidal clears with a wrap of wide butyl electrical tape....
    VR3 Posts: 29,695
    The top plate is not thick enough
    xschop Posts: 5,737
    Well luckily I have a spare 3/4" plate from the XS-amp project :)
    xschop Posts: 5,737
    My $23 JB inflationary 316S allen head bolt arrived...and its tech drawing was wrong. Was not a true 5" long flat head but 4.75". Adjusting accordingly.
    Post edited by xschop on
  • SeleniumFalcon
    Would you be willing to satisfy a curiosity of mine by measuring the DC resistance of the primary and secondary windings of your transformer?
    xschop Posts: 5,737
    Sure, Ill be on the project again tomorrow. Which leads do you want tested exactly?
    A flat head bolt will measure from end to end, so the bolt you received is actually 5” their print is wrong.
    That is how you measure say a hex head bolt or button head bolt.
    xschop Posts: 5,737
    It's an Ebay re-seller I'm sure. Ace Hardware doesn't even carry these. It's funny because you can't assume anything to ASTM specs any more. I've actually received UNC bolts with 90 deg tapers before.
  • SeleniumFalcon
    Thank you! If you could measure from the blue/violet pair to the grey/brown pair of wires. And then from the black/orange pair to the red/yellow pair of wires.
    xschop Posts: 5,737
    So not between individual wires, but between those pairs exactly?
    Just saw your reply.. I'll post results with my Fluke.
  • SeleniumFalcon
    Perfect, thanks!
    xschop Posts: 5,737
    Are you pondering how the amp would see the new impedance of the system with a dreadnaught vs a regular IC cable?
  • SeleniumFalcon
    SeleniumFalcon Posts: 4,357
    No, that isn't the reason, but that's an interesting point to consider.
    xschop Posts: 5,737
    I'll be experimenting with a nearfield SDA set-up and want to jumper (eliminate) the sub-bass drive inductors. I'll take a DCR reading of that when the time comes and post here.
    xschop wrote: »
    WHAT?? Why???
    xschop Posts: 5,737
    It'll be a continuation of my CRS+ crossover experiments. B)
