Projects: what are you all working on?
  • honestaquarian
    Been around since 1982
    pitdogg2 Posts: 27,677
    Not in my neck of the woods, My Carver Tx-11b had the ability but I've never had any stations.
  • skipshot12
    skipshot12 Posts: 2,112
    Removing this POS attempt that someone thought was a good idea to fix the power antenna in my vr4, if you can’t do it correctly don’t friggin do it!
    Aaaaah, that’s more better, now I can sleep well tonight.
  • stangman67
    stangman67 Posts: 2,330
    Whew that was an abomination! Good work!
  • skipshot12
    Thanks stang,
    With the whiffs help we have sweet quiet success.
    https://youtu.be/FIStlCNVBwQ
  • honestaquarian
    Wow @skipshot12 I had to remove my power antenna once and take it apart just like you did. I had to remove what was left of the old plastic tooth gear so that I could get the new antenna mast to go all of way down. Yours was WAY more involved than mine!
    Good job! B)
  • honestaquarian
    @pitdogg2 Where, when and how did you get your mitts on a TX-11b?!?!? :o
    JEALOUS!!!
    I wanted to get one to replace my TX-11a years ago, but whenever I would see one up for sale anywhere the seller would be asking premiums for it. Then the bidding war would start and the price would just be out of control. So I just gave up.
    I remember the TX-11a definitely sounded different from the TX-11.
    I had both.
    The TX-11 had woolly and undefined bass. Otherwise it was often confused for a Cd by some people.
    The TX-11a definitely had better bass and more precise imaging if I recall. The bass was the biggest difference though.
    No AM Stereo here in my neck of the woods when I had my TX-11a either (this was more than a decade ago)
    edited January 2024
    JEALOUS!!!
    I bought it off eBay, I paid about $300 for it sold it for $400 on ebay.
    I went through a tuner phase,
    many Yamaha's silver analog, black digital ect.
    Carver, Kenwoods and Sansui's. I'm still in possession of a Sansui TU-719, it took a swim☹️😢.
    I got close to the big Sansui Tx-Tu 1 whatever it was, it definitely was a holy grail tuner. I'll be damned if I didn't miss it by $20 .... I hope that guy loved it 😉
  • DaveHo
    DaveHo Posts: 3,584
    I stalled an attic ladder so I can easily access all the boxes for the audio equipment stored above the garage. Cost like $500 with the plywood I added. Money well spent?!😂
  • stangman67
    My audio boxes are both contained in the unfinished cubby holes in my finished attic and in the basement. It’s a bit out of control. The Focal Kanta boxes are giant, I’m shocked I was able to store them without breaking em down.
  • ChrisD06
    ChrisD06 Posts: 929
    Old photo before the drywall patching and priming but I'm renovating my bedroom.
    Ripped up the God awful carpet, gonna paint today or tomorrow and install luxury vinyl plank flooring.
    One problem that maybe you all could help me with: The subfloor is almost perfectly level but a couple nails are sticking up, and at some very specific points the seams between the subfloor panels are uneven.
    Could I just drive screws into the areas which are uneven, sand the floor, and grind down the nail heads/sink them further in? Figured one of you guys would know the solution to this minor problem.
    My gear:
    • TCL 75QM7K TV
    • Onyko TX-NR656 AVR
    • RT3000p Fronts
    • CS1000p Center
    • RT35 Side Surrounds
    • RT35 Rear Surrounds
    You should probably put some 1/4" underlayment on top of that before you put "luxury" vinyl planks on.
    Pull the problem nails and put decking screws in their place.
    treitz3 Posts: 20,237
    Gentlemen......the new site for Polkfest 2025....😀
  • Upstatemax
    Upstatemax Posts: 2,844
    treitz3 wrote: »
    You better have some good batteries, I’m off grid! :D
    xschop Posts: 5,685
    Nice digs. Hopefully your power supply can handle more than a Polk Soundbar. B)
    Started game-planning the XS-Dreadnaught...
    audioluvr Posts: 6,037
    Upstatemax wrote: »
    Is this the cabin you were telling me you bring your victims? Good choice!
  • jbreezy5
    jbreezy5 Posts: 1,141
    audioluvr wrote: »
    Upstatemax wrote: »
    Evil Dead 6(?)!
  • stangman67
    Awesome cabin! That’s a dream get away from it all spot!
  • Upstatemax
    audioluvr wrote: »
  • Upstatemax
    stangman67 wrote: »
    Yeah, it's a great place to get away. No internet, no cell service...
    It's also really close to some great mountain biking and right out the front door, I have access to miles upon miles of gravel roads when I want to ride my gravel bike.
    This springs first project is cutting in a proper shooting range, archery and boom sticks.
  • ChrisD06
    ChrisD06 Posts: 929
    Here's the project now.
    Paint turned out really nice! The color looks even better in person on the walls than it did on the paint chip. Most of the floor is done, just a few more rows and I've gotta go get some trim.
    Never done trim before (or paint or flooring but I managed those well) so I'm gonna grab my Dad's miter saw and do my best, caulk the rest. Will need to buy a nail gun too.
    My gear:
    • TCL 75QM7K TV
    • RT3000p Fronts
    • CS1000p Center
    xschop Posts: 5,685
    Might want to at least put a plastic sheet barrier as underlayment. JM2C
    Honestly if it were me 1/4" launan mahogany underlayment would have been used on top of the OSB board. I've seen too many times, the OSB woodchip pattern can start showing through the vinyl on top (especially if glued) due to it's imperfect nature. This why you should always use a smooth surface underlayment on top of your OSB subfloor.
    Viking64 Posts: 7,736
    Well, in 2 years, that horrific, trendy gray crap will fall out of favor on Pinterest and tens of thousands of sheeple will be redecorating with the next godawful atrocity.
  • Gardenstater
    Gardenstater Posts: 4,862
    edited February 2024
    When I did an adhesive vinyl tile job for someone many years ago I used 1/4" Baltic Birch (stapled down with seams mudded and sanded) because it doesn't have any voids. Luan Mahogany ply can have lots of voids in my experience but that might not be as much of an issue with a flooring product like Chris is using here. FWIW.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    . . . . that might not be as much of an issue with a flooring product like the contractor Chris' parents hired is using here. FWIW.
    *fixed
  • motorstereo
    motorstereo Posts: 2,400
    A new rack made from butcher block has been keeping me busy the past few days. Stained it light walnut today and tomorrow I'm hoping to start with the poly.
  • stangman67
    That looks very nice! Very excited to see the finished result
  • ChrisD06
    ChrisD06 Posts: 929
    Viking64 wrote: »
    *fixed
    No I'm genuinely doing this myself lol I wish I had hired a contractor because I'm EXHAUSTED
    My gear:
    • TCL 75QM7K TV
    • RT3000p Fronts
    • CS1000p Center
