Cullen Cable Avius power cable
marvda1
5ft Cullen Avius power cable with upgraded connectors. Cullen thinks with upgraded connectors his Avius cable sounds better than his crossover series cables.
12 awg x 3 (99.99% OFC Copper Conductors)
Super Flexible
110% coverage of spiral wrapped Aluminum Mylar Shielding with 20 awg tinned copper drain wire.
PVC – Polyvinyl Chloride dielectric
25 Amp Rated
14mm in diameter
Made in the USA!
$140 shipped paypal f&f
These work great as a source cable, but I was able to get away with using it on amps.
Super Flexible
25 Amp Rated
14mm in diameter
Made in the USA!
Puritan PSM156
Puritan PSM156
$130 shippedAmplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
$120 shippedAmplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
$110 shippedAmplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
$100 shippedAmplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
bumpAmplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
Puritan PSM156 -
Puritan PSM156 -
SOLDAmplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156
