R700 w/Sony AN1000
Hello Polk community!
I would love any opinions on whether the Sony AN1000 can power the R700's. As you can imagine, as I explore the interwebz on this subject, I get differing opinions on the types of equipment that are needed.
Thank you for your feedback!
    F1nut Posts: 51,763
    Will you hear music? Yes. Will it be as good as possible? No.
  • TheBob
    TheBob Posts: 4
    Do you think the Onkyo rz50 would be a better choice?
    F1nut Posts: 51,763
    Before going any further, is this for HT or 2 channel?
  • TheBob
    TheBob Posts: 4
    Oh yeah, totally...should have clarified.
    This will primarily be for HT but potential for more music listening as well.
    Thank you for your response.
    F1nut Posts: 51,763
    Ok, I'll presume you will run the R700 as small crossing the bass to your sub, so either AVR would work.
  • TheBob
    TheBob Posts: 4
    Thank you, appreciate that!
