Turntable Dust Covers
skipshot12
Did not know where to post this….
Any vintage tt gurus here?
What I have is a, actually have two, Sony PS-x75 vinyl spinner and one of the dust cover’s busted up.
Does anyone know what other PS-x tt model dust covers that are the same as the x-75?
There are many aftermarket ones still available but, I’m a stickler for originality.
Skip
Skip
^^^ This is my Sony PS-X70. I just measured it's dust cover.
It measures 18 3/8" across, 13 7/8" front to rear, and 3" high.
How bad is the original dustcover? Can you feel the scratches with a fingernail? Are you willing to put in some elbow grease?"This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
^ Broken in three pieces.
Thanks aprazer,
Would you happen to have a photo of the rear of your x70.
Trying to figure out if the x75 cover is a one of a kind?
The x75 was damaged. And, I think the dust cover hinges are non replaceable as they’re molded as part of the base? -
Just get one made that fits over the entire TT.Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
Tanks Mark,
May have to end up going that route…. -
skipshot12 wrote: »Thanks aprazer,
Not the greatest photo. I forgot how heavy these are!
You could contact eBay seller 'JnB Audio' for a possible custom build. The result would definitely not be 'original', but I have had positive results with them.
The weight/thickness of the material can come into play. If it's too heavy, the hinges won't hold the dustcover up, so sometimes a fine line there."This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
