Turntable Dust Covers
Did not know where to post this….
Any vintage tt gurus here?
What I have is a, actually have two, Sony PS-x75 vinyl spinner and one of the dust cover’s busted up.
Does anyone know what other PS-x tt model dust covers that are the same as the x-75?
There are many aftermarket ones still available but, I’m a stickler for originality.
Skip
  • aprazer402
    aprazer402 Posts: 3,428
    ^^^ This is my Sony PS-X70. I just measured it's dust cover.
    It measures 18 3/8" across, 13 7/8" front to rear, and 3" high.
  • jdjohn
    jdjohn Posts: 3,402
    How bad is the original dustcover? Can you feel the scratches with a fingernail? Are you willing to put in some elbow grease?
  • skipshot12
    skipshot12 Posts: 2,094
    ^ Broken in three pieces.
  • skipshot12
    edited January 2024
    Thanks aprazer,
    Would you happen to have a photo of the rear of your x70.
    Trying to figure out if the x75 cover is a one of a kind?
    The x75 was damaged. And, I think the dust cover hinges are non replaceable as they’re molded as part of the base?
  • marvda1
    marvda1 Posts: 4,964
    Just get one made that fits over the entire TT.
    Puritan PSM156
  • skipshot12
    Tanks Mark,
    May have to end up going that route….
  • aprazer402
    skipshot12 wrote: »
    Thanks aprazer,
    Not the greatest photo. I forgot how heavy these are!
  • jdjohn
    jdjohn Posts: 3,402
    You could contact eBay seller 'JnB Audio' for a possible custom build. The result would definitely not be 'original', but I have had positive results with them.
    The weight/thickness of the material can come into play. If it's too heavy, the hinges won't hold the dustcover up, so sometimes a fine line there.
