Anyone have some short XLR pairs they want to unload?
billbillw
I'm looking to buy some lower to mid-range quality XLR ICs. Looking at least for one short pair. Something like 1-3ft in (0.5-1.0m) length. If you had a 2nd pair that matched, I'd consider that as well. The 2nd pair could be up to 2m in length. Looking for something in the $100/pair or less range. May extend for a good deal on something higher. Lemme know whatcha got. Time to make some small changes.
I still have these. Offers considered.
https://forum.polkaudio.com/discussion/197888/furutech-alpha-6ft-xlr-for-sale#latest
2 Channel Rosso Fiorentino Volterra II, 2 REL Carbon Limited, Norma Revo IPA-140B, Norma Revo DAC-2, Lumin U2 Mini, VPI Prime w/SoundSmith Zephyr MIMC, Modwright PH 150, Denon DP-59l w/Denon DL-301MKII, WAY Silver 3 Ana+ Speaker Cables, WAY Interconnect Cables, AudioQuest Niagara 7000 w/Dragon, WAY power cables for all other sources. -
Just one pair of 6ft-ers? A bit too long unless you had a matching shorter pair. -
I've got some 1m Monoprice Premiere Series ones you can have. I think I used them once then found the WW Silver Eclipses I have now.Gustard X26 Pro DAC
Thanks for the offer, but I wanted to go a little higher than the base Monoprice. So me being impatient, I decided to just go ahead and order some WBC Mogami 2549 finished with Neutrik Silver connectors in a 4-pack. I really just wanted to have a complete balanced path from DAC>Preamp>Amp and not have different cables skewing things. I may revisit with higher end cables at some point, but I generally don't go crazy with expensive cables.
Nothing wrong with Mogami, nice choice.
Yeah, and the best part is free Prime shipping
I may end up replacing all my "old-as-hell" RCAs with this stuff too. -
Yep, thats the only one I have. Had a shorter one but sold it last year.
