Good Grief...what have I done! Man oh man I've opened a can of worms with this one.
I'm ditching my preamp & running my DAC straight into my amp. I never gave it much thought before but now with my newly acquired L.K.S. DAC from fellow Polkie PSOVLSK (aka Paul) I had that option to give it a try.
Now I've had my tube pre for about a year & really liked it, rolled numerous 6SN7 tubes (JJ's, TUNG-SOL, PSVANE) & they all added a different flavor & out of the bunch I liked the PSVANE. I was going to try others but I just enjoyed it & stayed with what I had.
Very musical, just enough bloom without sounding too "Tubey" I was quite content. Now enter the L.K.S. DAC...a wonderful sounding DAC that exceeded my expectations. At first I didn't even realize that I could give it a whirl straight into my amp & forego the preamp.
Since I'm 100% digital & I don't have any other sources (CD, SACD, vinyl) besides my modded NODE 2i streaming Qobuz & Spotify I figured why not try it. If I had multiple sources then I'd definitely need a pre for source selection & volumn control. And since I run my dual REL subs via hi-level connection I don't need a pre-out for them either.
I was totally expecting to be rather disappointed but boy oh boy was I ever wrong. The music now sounds so much more natural, laid back & just more enjoyable to my ears. Maybe I'm just not as much of a tube guy as I thought. Not that I don't enjoy the tube sound this just sounds way better & more engaging to my ears. I'm assuming that as good as the DAC sounds they also have a killer analog stage in there too that just makes the music blossom. For now I'll still keep the pre & alternate every now & then just to switch things up a bit.
«13
    VR3 Posts: 29,429
    edited December 2023
    been pre free since... 2021??? no regrets!!!! Better than having a preamp any day! Has nothing to do with the tubes, just more to do with removing a completely unnecessary component in the chain
  • pearsall001
    pearsall001 Posts: 5,294
    VR3 wrote: »
    I can attest to that from what I'm hearing. Being 100% digital there is no need for a source selecter & volume control piece. The less the better.
  • motorstereo
    motorstereo Posts: 2,342
    I thought about doing that as well and freeing up some real estate in the rack. I had my hopes up and gave it a shot. The results were less than impressive so the pre went right back in. Might've been an impedance mismatch as the soundstage really went to hell.
    VR3 Posts: 29,429
    What is your streamer
    heiney9 Posts: 25,432
    VR3 wrote: »
    Volume control???? Please don't tell me you're using the volume control output from the BlueNode or Quobuz app? Those things are horrible and should always be set to "fixed" because of that.
  • erniejade
    erniejade Posts: 6,321
    I am glad you are digging the LKS. That unit for the $ even new is no joke. Marvin and I both kept saying it punches way above its price point. I still want to hear their newer one.
    @marvda1 have you ever got your ears on their newer one?
  • marvda1
    marvda1 Posts: 4,950
    Not yet, I have been enjoying this Sonnet Digital Morpheus rtr dac.
    Puritan PSM156
  • pearsall001
    heiney9 wrote: »
    VR3 wrote: »
    None of the above. The DAC comes with a full feature remote. Easy peasy. 8bacnb1t7gu9.jpg
  • pearsall001
    VR3 wrote: »
    Modded NODE 2i using LHY PSU board.
  • motorstereo
    VR3 wrote: »
    In my case it's a Cambridge Audio 851n Azur going into Mcintosh mc1201's.
    heiney9 wrote: »
    VR3 wrote: »
    Still, an in expensive I/C to control volume? I'll take an analog stepped or expensive discrete controlled digital volume control.
    Rock on with whatever works for you
    VR3 Posts: 29,429
    I have put digital volume controls up against some nice preamps and the digital volume hasn't lost yet.
    Musical fidelity kw preamp
    Cary slp9
    To name a few
    nooshinjohn Posts: 25,927
    I have been reading some reviews recently of preamplifiers. Many of these reviewer‘s were using their DAC’s directly to the amplifiers as well, with no preamp in the system. Some of them ended up buying the preamplifier they were reviewing because it improved the overall quality of the sound in their systems. The general consensus among these reviews was that the preamplifier did a better job of accurately, presenting the sound stage, with better placement of instruments, better control of frequencies across the audio spectrum, and a host of other improvements.
    The reviewers were not using entry-level digital gear in their review either. That said, the amplifiers I have been looking at all have a retail price about 10 grand. I would expect there to be some improvement when purchasing a component at that price point or higher.
    billbillw Posts: 7,547
    VR3 wrote: »
    Cary slp9
    To name a few
    The implementation of digital volume control (or fixed output with an IC controlling volume) can vary greatly. I, for one, am not getting rid of my pre-amp any time soon. It is needed with my setup, since I still have a phono preamp and a tuner that I use in addition to my DAC/Streaming pathway. For about a year, prior to picking up my STP-SE, I did use the output from my DAC, which has a volume control knob, and I found it lacking dynamics and level matching. I'll admit, my DAC is not high end, but I think still think a preamp with good input/output buffering and a resistive ladder volume control is going to win out over most digital volume controls, whether it be a software or IC method.
    Trey, both the examples you mentioned (kW pre and Cary) both use old school potentiometers for volume control, so despite them being well respected, they are not the ultimate when it comes to preamp/volume control.
    VR3 Posts: 29,429
    Now I have tried a passive preamp in between with a super nice ladder resistor volume and that lasted all of five days.
    I may need a preamp in the future but I would easily put the lumin leedh volume control against any preamp on the market without second guessing it.
  • Emlyn
    Emlyn Posts: 4,714
    A preamp section with a volume control is still involved, it's just not in a separate box. I can understand why an all digital system might work better this way though. Less stuff involved. Depends on how well designed and isolated the preamp section is in the streamer or DAC compared to the standalone preamp.
    treitz3 Posts: 19,992
    Just sayin'...
    The IC used between any components can also have a "make or break" affect as well. Even the PC's in certain systems can do the same thing.
    Every system and system setup varies. Lots of variables here to consider.
    In my case, I have to have a pre. Too many sources. I'm perfectly happy with what I am hearing.
    That said, I am happy for you Phil. Little discoveries like this to enhance your system (especially for the cost you laid out for this one) are awesome. Enjoy.
  • gyosa
    gyosa Posts: 770
    I’ve been preamp free for years .
    Couple of Yamaha wxc-50’s straight into the amps in secondary systems…
    And an 851n straight into the amp in my main rig…. Sounds great … i read a technical review years ago about how good the 851’s volume control is..
    May have said it was actually analog , cant remember…
    851 has now been replaced with a DMP-A8 as of last week ….. straight into the amp … sounds fantastic…
    Bk
    PS Audio S300 , WiiM Ultra , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 48” - BEDROOM
    B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
    Parasound A21, Eversolo DMP-A8 , Kimber Kable 4vs , Ascend Acoustics ELX Ribbon Towers , Sony XBR-A8F 65” OLED - DEN , MAIN system
    Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO
  • gyosa
    gyosa Posts: 770
    I have an old PS Audio 4.6 preamp I got new in 1989-90 or so …. Still have it.
    Used it for years in my system- straight wire mode … basically a passive pre in that mode with a fantastic volume control…. It could use the external power supply by turning the selector to “on”.
    The only time I ever used the power supply was when spinning records - there just wasn’t any need to as the cd player and tape deck put out ample voltage.
    Bk
    VR3 wrote: »
  • pearsall001
    treitz3 wrote: »
    Just sayin'...
    I'll tell you what it really surprised me & it was subtle either.
    For now I'm going to park any notions of picking up another pre. Being 100% digital I can avoid that expense for now anyway. I really don't think I'll be adding any other source to warrant picking up another pre. And this puppies volume control is fantastic...no complaints here.
    One thing I've learned over the many years in this hobby is that spending more does not always equate to getting more. It never ends though. Lol!
  • bcwsrt
    bcwsrt Posts: 2,413
    Phil, two things: 1) Time to update your signature and, 2) You didn't mention it here, like you're hoping we'd forgotten about it, but ... you still owe us a REL sub review!
    My new DAC has a volume control, also, which on the surface I was thinking "WTF good is that for?!" But, although I have an integrated amp and need its phono stage, the DAC volume control has come in quite handy to match volumes between sources. It's nice to have options and be able to experiment, as you have found.
    Enjoy!
    Brian
  • motorstereo
    Amazing how we all vary in what we hear. Several years ago I tried using my now outdated Mcintosh d100 dac as a preamp. My intention was to leave vinyl behind and simplify things. That experiment didn't go as planned. I have a 2 piece preamp and I was really hoping it would as the dual pre pieces are major space hogs. The d100 dac takes up a half space so that would've freed up a lot of room and eliminated several connections. The result was the preamp stayed put and the Mac dac has been doing duties as a dust collector.
    Left and right tracking and digital hash and other artifacts are some of the negative things about an inexpensive I/C based volume control.
    BAT and PASS Labs have had a few articles about how important a well designed and implemented volume control is.
    We all hear differently, all have different expectations and all are willing to compromise more than others. If it floats your boat go with it. But it would never work for me, as I have heard the other side and there's no going back. Just like I/C based op-amps were fine and perfectly acceptable until, after hearing discrete op-amps, there is no going back. The difference is so apparent........there is just no going back.
    I have never had good luck using the "built in" volume control on anything as a pre-amp has always been better.
    All that said, I haven't heard either of the systems mentioned (Phil's or Trey's) so I am speaking in generalizations. And I have no doubt the better the gear the better some of the implementation is.
  • invalid
    invalid Posts: 1,456
    Going straight from the DAC into the amp also depends on the input sensitivity of the amp and the sensitivity of the speakers being used.
    VR3 Posts: 29,429
    So my speakers are 95db 1w1m and I usually run the volume 80 out of 100 on the digital scale... No gain required beyond unity
  • invalid
    VR3 wrote: »
    My amp needs 2.5 volts for full power and one of pair of speakers I own is 80db sensitivity and the other pair is 92db, so I use a preamp.
    tonyb Posts: 33,072
    I do the same Phil, dac to amp. Don't get me wrong, while the sound is OK, I'd still prefer a nice tubed pre amp in the mix. Simply because I don't get to use the system much and it's now just used as background music, cost wise, makes no sense to keep adding more seperates.
    However, you might convince me with that Lampizator tubed dac that I would trim nose hairs from Russ to get one of those bad boys. I just dig the tube sound, and the adjustments that can be made rolling tubes.
  • pearsall001
    bcwsrt wrote: »
    Enjoy!
    I know I'm slacking. Lol! But don't worry I didn't forget. It's just so crazy this time of year. Patience grasshopper 🦗🦗🦗 patience.
    txcoastal1 Posts: 13,513
    It's about impedance output from the source to the amp and the attenuator ie volume control
  • jbreezy5
    jbreezy5 Posts: 1,141
    VR3 wrote: »
    Getting closer, but passive pres sound rather lifeless, imo.
    Would be interested in your impressions comparing digital direct vs. a pre with discrete resistors and optical encoder, like STP-SE, other others akin, Pass XP12, Classe Delta Pre, etc.
    I should try digital direct too. Good discussion.
