Looking for an integrated amp with good bass
muncybob
My daughter recently had me swap out an old Technics integrated for an equally old Denon AVR so I could connect to her TV. She's not happy with the sound, esp streaming from her phone. Like her father, she's a bit of a bass head and I think that's where the AVR falls short. Any suggestions for her with a budget probably around $500?
Yep, my name really is Bob.
Soooo.... What is actually providing the bass? Speakers? Sub?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
And, what does she stream through, the avr?Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Bass only thru 2 speakers. She streams using some sort of thingy connected to the amp. She probably would get better sound if the amp had a DAC/bluetooth, right?Yep, my name really is Bob.
Parasound HCA1500A(indoor sound) and HCA1000(outdoor sound), Dynaco PAS4, Denon DP1200 w/Shure V15 Type V and Jico SAS stylus, Marantz UD7007, Polk L600, Rythmik L12 sub. -
Is this the monitor audio speakers?
I would try to find an Bluetooth dongle like e sinkin brand and then a parasound hca amp and then run Bluetooth out of the TV and use the TV volume- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
No amp will create deep bass from speakers that are undersized. Cost wise, it would probably be cheaper to get a used 12" sub with a built in class D amp (that is assuming the Denon AVR has a sub pre-out). If she is streaming via BT, there is no such thing as "better sound."
The Bluetooth dongle can also connect with her phone and she can use her phone as the volume control- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I agree with others, there are several options to address the issue. But to answer your original question, something like this would be great:
https://www.ebay.com/itm/295900978204?hash=item44e5129c1c:g:QBEAAOSwsANk6WSC&amdata=enc:AQAIAAAA0PRycwT6tBARt9SErL3MulqG7WTEluHLLK/YKDIkZzoy4i1L3WMgouBHRkOhwm89cORjiZ7v6Hjhshgf0GX9dWUKPtTxsp35N8FqEpvj7c/38x0qHYhMGOFi/ku0OcZTs1aK+BtGsdfHOdyhsRfvIwgXuReeCODUEN0v7teR4mLBi2PUIFKYX6Gk02D+Jg1hmfJwfykatjr/tX6XbLDKSXeinFou3nXgFtqGgAXfZEMgctHtmfrKOBl2GFXPywiv4mA1wB3JO/lMooSfccIPCW8=|tkp:Bk9SR7DxoaGLYw
That one is fugly, but any of the 840a, 740a, or 851a would do the trick nicely.
Also a nice option, with the advantage that it has a DAC:
https://www.ebay.com/itm/256116806691?epid=23043385348&hash=item3ba1c05423:g:19UAAOSwMY9eKyAoLiving Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Yep, those are the speakers. I don't follow how you get audio to the amp from the TV. I think she currenty has a bluetooth dongle and uses her phone for volume.Yep, my name really is Bob.
You need a Bluetooth dongle with rca left and right out. I run this arrangement for my office rig and it works perfect- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
That would probably save her some $$..or even give me a chance to gift her my HCA1000 and upgrade
I do like the Cambridge amps though!Yep, my name really is Bob.
The method of streaming could limit the bass reproduction. It's all about the source.
Did the Technics provide adequate bass but the Denon AVR doesn't? I have found that with hard to drive speakers, the amp does matter in the bass department. I had a Denon DRA-835R that could push RTA-11TL quite well but when I tried a Denon DRA-888 it sucked even though wattage ratings were similar. It has to do with the current drive capability of the amp.Stan
Main 2ch:
HT:
Other stuff:
Yea Stan, I'm sure that's the case. She liked the Technics sound. I would go with the dongle into the Technics amp but she won't get the TV shows thru her speakers.Yep, my name really is Bob.
Youch -- talk about 21st Century problems!
Amazon has lots of cheap DACs with optical in and rca out for less that $50. That should get the audio from her tv to her speakers…Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
@muncybob I have one I’ll sell super cheap, along with an optical cable. $30 shipped for both.
https://www.amazon.com/FiiO-D03K-Digital-Analog-Converter/dp/B009346RSS/ref=mp_s_a_1_31?crid=2JFB6H30L69LW&keywords=fiio+dac&qid=1702394369&sprefix=fio+dac,aps,260&sr=8-31&ufe=app_do:amzn1.fos.17d9e15d-4e43-4581-b373-0e5c1a776d5dThings work out best for those who make the best of the way things work out.-John Wooden -
If her current dongle doesn't have the jacks needed, I'll take it. Waiting for a photo from her.Yep, my name really is Bob.
Instead of an amp with Bluetooth and a dac, check out a wiim pro plus and use your current amp?Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
Looks like the FiiO will be the answer....PM sent.Yep, my name really is Bob.
RepliedThings work out best for those who make the best of the way things work out.-John Wooden
