Looking for an integrated amp with good bass
My daughter recently had me swap out an old Technics integrated for an equally old Denon AVR so I could connect to her TV. She's not happy with the sound, esp streaming from her phone. Like her father, she's a bit of a bass head and I think that's where the AVR falls short. Any suggestions for her with a budget probably around $500?
Yep, my name really is Bob.
    VR3 Posts: 29,483
    Soooo.... What is actually providing the bass? Speakers? Sub?
  • rooftop59
    rooftop59 Posts: 8,120
    muncybob wrote: »
    And, what does she stream through, the avr?
    Game Room 5.1.4:
    Bedroom 2.1
  • muncybob
    muncybob Posts: 3,258
    Bass only thru 2 speakers. She streams using some sort of thingy connected to the amp. She probably would get better sound if the amp had a DAC/bluetooth, right?
    VR3 Posts: 29,483
    edited December 2023
    Is this the monitor audio speakers?
    I would try to find an Bluetooth dongle like e sinkin brand and then a parasound hca amp and then run Bluetooth out of the TV and use the TV volume
    billbillw Posts: 7,669
    No amp will create deep bass from speakers that are undersized. Cost wise, it would probably be cheaper to get a used 12" sub with a built in class D amp (that is assuming the Denon AVR has a sub pre-out). If she is streaming via BT, there is no such thing as "better sound."
    VR3 Posts: 29,483
    The Bluetooth dongle can also connect with her phone and she can use her phone as the volume control
  • rooftop59
    Game Room 5.1.4:
    Bedroom 2.1
  • muncybob
    VR3 wrote: »
    Yep, those are the speakers. I don't follow how you get audio to the amp from the TV. I think she currenty has a bluetooth dongle and uses her phone for volume.
    VR3 Posts: 29,483
    You need a Bluetooth dongle with rca left and right out. I run this arrangement for my office rig and it works perfect
  • muncybob
    That would probably save her some $$..or even give me a chance to gift her my HCA1000 and upgrade :)
    I do like the Cambridge amps though!
    heiney9 Posts: 25,482
    The method of streaming could limit the bass reproduction. It's all about the source.
  • skrol
    skrol Posts: 3,455
    Did the Technics provide adequate bass but the Denon AVR doesn't? I have found that with hard to drive speakers, the amp does matter in the bass department. I had a Denon DRA-835R that could push RTA-11TL quite well but when I tried a Denon DRA-888 it sucked even though wattage ratings were similar. It has to do with the current drive capability of the amp.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • muncybob
    Yea Stan, I'm sure that's the case. She liked the Technics sound. I would go with the dongle into the Technics amp but she won't get the TV shows thru her speakers.
    mhardy6647 Posts: 35,131
    muncybob wrote: »
    Youch -- talk about 21st Century problems! :(
  • rooftop59
    Amazon has lots of cheap DACs with optical in and rca out for less that $50. That should get the audio from her tv to her speakers…
    Game Room 5.1.4:
    Bedroom 2.1
  • PSOVLSK
    PSOVLSK Posts: 5,396
    rooftop59 wrote: »
    @muncybob I have one I’ll sell super cheap, along with an optical cable. $30 shipped for both.
    https://www.amazon.com/FiiO-D03K-Digital-Analog-Converter/dp/B009346RSS/ref=mp_s_a_1_31?crid=2JFB6H30L69LW&keywords=fiio+dac&qid=1702394369&sprefix=fio+dac,aps,260&sr=8-31&ufe=app_do:amzn1.fos.17d9e15d-4e43-4581-b373-0e5c1a776d5d
  • muncybob
    If her current dongle doesn't have the jacks needed, I'll take it. Waiting for a photo from her.
  • erniejade
    erniejade Posts: 6,321
    Instead of an amp with Bluetooth and a dac, check out a wiim pro plus and use your current amp?
  • muncybob
    Looks like the FiiO will be the answer....PM sent.
  • PSOVLSK
    Replied
