Need help with rti 12 repair
So I left my amps on while I was at work one day and I came home to the smell of burnt voice coils in my room. Low and behold one of my RTI 12's had cooked two of the three 7" woofers. After searching for Rd7225-1 replacements I could not find any. However there are plenty of Rd7224-1 replacements around which are the 7" woofers used in RTI 10's.
Any chance I can use the Rd7224-1's as replacement on my RTI 12's
    pitdogg2 Posts: 27,184
    First I'd be finding out why the speakers got fried. Something is wrong.
    billbillw Posts: 7,699
    Sounds like your amp(s) is sending DC current which is bad. Check with a multimeter before hooking any speakers to it again.
    F1nut Posts: 51,899
    edited December 2023
    bernouski wrote: »
    Considering they have different part numbers the drivers will have different specs. How different I can't say. Perhaps a call to Polk is in order.
    Edit: It looks like they may still be available, but currently out of stock. I'd contact Encompass to see if they have more info.
    https://encompass.com/item/5852046/Polk/RD7225-1/
  • Geoff4rfc
    Geoff4rfc Posts: 2,911
    bernouski wrote: »
    This was helpful information....wonder if dude followed your advice and found his solution???
    Set up: 11.2 HT + 2ch
    Cables: Mogami AES from CDP to DAC - AQ McKenzie XLR from DAC to AVP to amp for 2ch, Emotiva XLR's for the rest - Douglasconnection: Furutech Alpha 36 12g speaker wire for 2ch, Furez 10g speaker wire for the rest - AQ Forest48 HDMI for the display, AQ Carbon48 HDMI from BRP to AVP - VR3 filtered power cables for CDP, BRP and AVP, Emotiva power cables for the amps - AudioQuest 707 power conditioner.
