Maginifi one soundbar sub sync light won't turn on
oneoneoneone
Maginifi one soundbar turns on and the subwoofer turns on but the sub sync on the bar doesn't and won't connect to the subwoofer.
Answers
It might be a good idea to unplug the AC for both the soundbar and the sub, wait a few minutes re-connect the power and try the synchronization again. Sometimes you have to repeat this a few times.
Thank you for your help!
I tried the process you mentioned a couple of times and the soundbar only turned on twice for a couple of seconds and then back off before it could connect to the subwoofer. Is there anything else I could try to get them to sync together? -
Let me ask a friend at Polk. It may be a couple of days until I get a response. Hang in there.
I heard from him, he recommends contacting Polk's support team by visiting Customer Support | Polk (polkaudio.com)<https://www.polkaudio.com/en-us/contact-us.html> or by calling Product Support at 800-377-7655
Thank you again!
