Danny Richie tests LSIM703
marvda1
marvda1 Posts: 4,875
Speaker Cables: Organic Audio Organic Reference 2
Interconnects: Argento Organic Reference 2, Argento Organic 2
Puritan PSM156
    VR3 Posts: 28,054
    I like how the video stops and he comes back in to talk about how difficult this install would be. The part where he says you could put those parts all over the enclosure internally is awful and should be removed from the video.
    External is the only option for the 703 for a full rebuild
    xschop Posts: 4,707
    What is the Freq. cutoff of the woofer? Just curious.
    pitdogg2 Posts: 24,588
    xschop wrote: »
    Did you watch the video? He has graphs of the testing.
  • Gardenstater
    I'll have to watch again. I thought he did say that an external mount with the crossover inside a stand is the way to go and that the components would actually take up too much internal enclosure volume compared to the original 2 board crossovers.
    George / NJ
    Crown D150 amp
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    edited November 2023
    He did say that, he also did say you "could" BUT you would need to fiddle around with placement around all the bracing. He definetly alluded to the impossibility of doing it that way.
    xschop Posts: 4,707
    xschop wrote: »
    TY....@330 Hz . If I find a set, the mids would get plugged and the plastic frame swapped for solid alloy.
    VR3 Posts: 28,054
    The problem with the Lsim series at this point is the fact the tweeters are very unreliable and Polk doesn't have replacements
  • mantis
    mantis Posts: 17,058
    VR3 wrote: »
    I'm surprised by that. The LSIM's was one of their very best lines.
    Dan
    VR3 Posts: 28,054
    The days of long term legacy support seen to be over im afraid
    xschop Posts: 4,707
    Dayton tweeter to the rescue.
    Toolfan66 Posts: 16,930
    VR3 wrote: »
    I don't think any of us expect anything like they have done with the vintage SDA's and even that has dwindled over the last 10 years, but with lines like the LSiM, and Legend, and maybe even the Reserve, they should be able to have parts for at least 3 years after the death of the line, especially to the people that have the paper work that they are the original owners.
    My LSiM's have worked flawlessly since I purchased them, so even the three years really wouldn't have mattered for me.
    I do have a brand new set of 703's put away...
  • Emlyn
    Emlyn Posts: 4,373
    VR3 wrote: »
    I have had several pairs of these without any driver failures. But, I did notice that after driving a pair of LSiM703s at moderately high volume for an hour continuously with a Parasound A21 amp that the tweeter bezel was a bit warm to the touch. That seemed unusual to me so I turned the volume down to see if the issue would go away. It did.
    Of course the failures may have been caused a bad batch in production or the speakers may have been driven by inadequate current at some point in their lives. It could also have been a design issue with inadequate heat dissipation, but that's just a guess.
    As I recall when replacements were available they were relatively expensive. It's been decades since I blew a tweeter on a speaker but I remember when I did it was because of the speakers being overdriven with inadequate power causing too much heat for the tweeter to handle.
  • Emlyn
    Emlyn Posts: 4,373
    How does someone determine the point at which taking up more cabinet volume with larger crossover parts will have an effect on speaker performance? Is there a way to counteract the volume loss somehow with less internal insulation material? Or does it matter at all if the speaker is ported or not ported?
    F1nut Posts: 49,808
    My logic says more than a 10% loss of internal volume will affect the performance.
  • invalid
    invalid Posts: 1,280
    Emlyn wrote: »
    VR3 wrote: »
    The amp may have been clipping on the transient peaks, most amps do not have an overbuilt regulated power supply including the parasound a21. Try an amp the can double down to 1ohm, I guarantee that would not happen.
  • MLK
    MLK Posts: 15
    Toolfan66 wrote: »
    VR3 wrote: »
    I wonder if California's right to repair law that goes into effect 7/1/2024 will require Polk to continue to carry replacement parts for 7 years after production. I know this is only in California, but the state has a lot of pull to affect manufacturers for the rest of the country/world.
    Of course, this likely will not pertain to LSiM line, just current Polk products (on 7/1/2024).
    https://www.androidauthority.com/california-right-to-repair-law-3374535/
    xschop Posts: 4,707
    MLK wrote: »
    Toolfan66 wrote: »
    VR3 wrote: »
    That thinking is akin to requiring you to own an electric lawn-mower....
  • mpitogo
    mpitogo Posts: 478
    That is TWO now (first the L600) and now LSiM man Polk engineers are great. It's great validation of we already know.
    • Living Room Music-2.0 Polk Legend L800 | McIntosh C70 | McIntosh MA5200 (Treble) | McIntosh MC452 (Bass) | Sublimeacoustic K231 Active xover | Denon DP-2500A | Denafrips Ares II | Belkin Soundform Connect | iPad Air USB to DAC
    • Media Room Ht-7.2.6/13.1 (Atmos/Auro-3D) Polk LSiM707, LSiM706c, LSiM702 F/X [x4], height LSiM703 [x6], HSU VTF-15H MK2 Dual | Marantz AV8805A | Rotel RB-1590 (L/R) | Appollon NC500 11ch | Sony UBP-X800 | AppleTV 4K | JVC RS2100 | 150” Elite Screen Acoustic Pro UHD
    • Game Room-5.1 Polk LSi25, LSiC, LSiF/X | Marantz SR7009 | AppleTV 4K | Xbox One S | Sony PS2, PS3 | Nintendo Wii | Gaming PC | Sony 75" LCD
    • Master Bedroom Music-2.0 Totem Hawk | Marantz PM-10 | Marantz SA-10 | SONY PS-HX500
    • Office-2.0 Ascend Acoustics Sierra LX, DSW microPRO3000 | Rotel RA-1570 | Marantz HD-CD1
    • Daughter's Bedroom 1-2.0 TBD Martin Logan Forte | Roku TV
    • Guest Room 2-2.0 Klipsch RP-600M | Martin Logan Forte
    • Guest Room 3-3.0 Martin Logan Motion 40, 50XT | Onkyo TX-SR705 | Apple TV | Samsung 55" TV
    • Guest Room 4-2.0 QAcoustics 3030i | Sansui AU-6900 | Topping DX7s | Sansui FR-1080 | Fire TV
    • Maintenance: Pro-Ject VC-S Record Cleaning Machine
  • skrol
    skrol Posts: 3,340
    I guess when we buy new speakers we should hit up the parts department for spares while they have them.
    Stan
    Main 2ch:
    HT:
    Other stuff:
