Volume is everything.
You may or may not agree.
Some folks love top volume level. Some others hate that. The thing is, in my own opinion, is that as one listens?
There is a drastic difference in simply cranking a song up and, "listening".
Listening for the perfect compromise between what a system can handle and what your expectations are.
The volume can make or break a system by one or two clicks. This all depends on a plethora of factors. This is system dependent. It also depends on what your threshold of distortion is and how you ears can handle it.
In my case? I cannot.
The varying of volume can make or break a presentation of enjoyment and bliss versus sheer pain.
When you offer up your system up to someone? Play it......not how you think they will enjoy it....
Play your system to where it sounds the very best, regardless of what you may think "your"prefererce of volume is". Play your system to where it shines the best.
    pitdogg2 Posts: 27,113
    edited November 2023
    Couldn't agree more. For me, a lot depends on the recording and song in question. A great recording by Allison Krause can take some juice. Something by say Metallica, back that sucker down by a Factor of 5 or more.
    Don't get me wrong I like to headbang a song or two, and that's about it anymore.
  • bcwsrt
    bcwsrt Posts: 2,428
    Anything above 70dB is “too loud” for the misses, though. 😳😩
    Brian
    heiney9 Posts: 25,465
    The better the gear the louder you can play without that feeling of "it's too loud". But, on the whole I get where you're coming from. It's also highly dependent on the source material. A crappy recording is going to sound poor played loud on even the best system.
    I've also found going up the chain in both gear and speakers a really good "system" can capture enough of the macro dynamics to make it almost as pleasurable listening at a low level. You will lose some scale, but it should still feel like a full presentation.
    I've found when gear needs to be "goosed" to a much high volume for it to sound good, the gear is not up to it or the synergy isn't there.
    I've found myself inching up the volume with the new amp, simply because it's so clean and clear w/o a hint of grain, harshness or distortion. Listening fatigue is pretty much non-existent so far.....again poorly recorded material by it's nature just never sounds very good loud.
    VR3 Posts: 29,455
    Wait, you mean there are multiple volume points on the volume control??? huh! :-D
  • ChrisD06
    ChrisD06 Posts: 927
    75dB for critical listening and 85-90dB for a damn good time
    My gear:
    • TCL 75QM7K TV
    • Onyko TX-NR656 AVR
    • RT3000p Fronts
    • CS1000p Center
    • RT35 Side Surrounds
    • RT35 Rear Surrounds
    treitz3 Posts: 20,032
    VR3 wrote: »
    So, you DO know this. Who knew?
  • Joey_V
    Joey_V Posts: 8,600
    Very good thread Tom
    I was just thinking of this the other day
    I just measured my listening volume 75 is typical
    But sometimes it creeps up.
    I hit 50 on the arc 10 pre. I checked my db meter and I’m hitting 105.
    I says… this is kinda loud. It’s about the point at which where I feel air in front of the Magico woofers. I’m thinking I should really turn on my subs to take some stress off…
  • motorstereo
    motorstereo Posts: 2,351
    The volume knob also controls how far outside the box the speakers image. The more the fun knob gets twisted the wider and more detailed the sound stage becomes.
    At least that's how it works here. No doubt other's mileage will vary.
    105 is loud if you're measuring from your listening position. But I do feel it's a bit relative to your room size too. I usually listen around 80 with peaks around 87-90. Now I have a smaller room and my couch is against a back wall. The sound has nowhere to really escape, except the left side is open into the dining room.
    I feel like if I had 3-4 feet of space behind my couch and had another opening on my right the readings would be the same but it wouldn't "seem" as loud. My room loads up fast.
    92, 93 in my room seems very loud.
    I like to listen moderately loud because I like to feel the visceral impact of bass.
    F1nut Posts: 51,855
    Feeling the sound is an important part of the listening experience.
  • maxward
    maxward Posts: 1,705
    It’s one reason why I never really warmed up to headphones.
    audioluvr Posts: 5,953
    heiney9 wrote: »
    Wait. Are we supposed to measure from the listing position? I'm thinking anything over 25 dB is too loud for the ol lady.
  • muncybob
    muncybob Posts: 3,249
    true dat. While I enjoy listening with my headset, if I really want to "get into it" it's cranked up a bit through the speakers.
    Yep, my name really is Bob.
    One of the things that I have noticed at various audio shows and even with auditioning people's rigs, is that they sometimes feel the need to crank the systems up to where they are amplifying audible distortion. They may not notice it, or maybe they feel that people would be more impressed with additional sound pressure in the room.
    The thing is, there does come a point to where a system and the room interact and the room starts to get overloaded. Of course, with more headroom, the system can be cranked up more but then what ushers in is the delicate balance between the system itself and the room. You can start to lose some of the attributes of the system because the room gets overloaded, masking the frequencies that offer you some of that essential imaging/spatial locationality cues. It blends in those images to where they get more collapsed onto each other, instead of being in there own space.
    If you have any overponderance of the lower registers, the room can quickly get excited. This is when the aforementioned happens and at that point, it becomes a detriment to one of the systems benefits, only to achieve more sound pressure/volume in the room. This is an attribute for parties or casual listening, when sitting in the sweet spot isn't a concern but it becomes a deficiency when critically listening in the sweet spot.
    I am not saying that all music should be enjoyed at 80db or at a certain volume. This is very song dependent.
    A single guitarist, or maybe a couple of unamplified guitarists up on stage - You would not want to listen to this at 95Db. Well, you may want too, and that is your choice, but I sure as heck wouldn't want too. That's unrealistic to me. At 95Db, you lose what can be. Yes, you will still be able to place where the guitarists are up on stage but you may lose the subtleties of the air within the chamber (body) of each guitar. Slides and fingers hitting the body of the guitar will become greatly exaggerated. You would be better to simply turn the volume down to a point to where you get the best blend of ALL of the attributes your system has to offer, while being at a realistic playback Db level....as if the 3 guitarists were in your room. Try to match the same Db level they would be playing at live, in front of you. Instead of an unrealistic 95Db.
    What I am saying is that sometimes less is more.
    At last year's LSAF, I walked into the Raven room. They had two rooms and the one I am talking about is the larger of the two rooms. Long story short, the guy babbled on about how great the speakers were, about how many awards they had won, blah, blah, blah. Then he finally shut his yap and played the music.
    I had to leave the room. It was so loud for the selection they were playing, that they didn't even realize they were amplifying distortion. It was that distortion that eventually drove everyone out of the room. They all stayed to listen to what he had to say but when the music started playing? They all scattered out of the room like cockroaches when you flip the light on. The time from him hitting play to an empty room (besides two gentlemen discussing something in another area of the room) was an estimated elapsed time of about a minute.
    Now granted, this was a worst case scenario at an event. BUT, it has happened too many times in my travels, albeit to a lesser degree. I can't tell you how many rooms I have walked out of because the system operators didn't know what their system was capable of and they simply cranked it. What they thought was a good thing, actually became a detriment.
  • mantis
    mantis Posts: 17,515
    As a Musician, I tend to favor slightly louder than usual. I like to Feel the music and sometimes it takes a bit of room pressure to make that happen.
    I'm also a Metal guy at heart so there is that
    Dan
  • smglbrth
    smglbrth Posts: 1,496
    Agree with the above statements. For me, it only takes one or two turns of the volume to make, or break, the music. Some I can crank, some I can't. Mostly rock on average for the latter. I told my sons that "less is more" when it comes to music. If the music is very "busy" it's harder to turn up, not always, but most of the time. For me, anyway...
    tonyb Posts: 33,071
    Cranking the volume, while not hearing any bad juju, retaining all the clarity and air.soundstage....that's heaven gents. Should all aspire to reach such heights in ones system.
    Agreed, a great system will allow you to do just that. There is still a limit though. That's the gist of what I am trying to get across.
  • bcwsrt
    bcwsrt Posts: 2,428
    I’ve been paying more attention to volume since this thread. I actually had a couple pretty long sessions last night and again this morning at lower volumes and still enjoyed it immensely. I was doing some work on my MacBook both times, so that was the main reason for the lower volume, but I found myself going “Damn!” a few times when something magical stuck out. Might get a little more out of dynamic range fluctuations at lower volumes?
    It wasn’t a live-like experience that you get with higher volume, but it was still engaging enough that I lost my concentration on what I was doing several times. I agree with @heiney9 that “The better the gear the louder you can play without that feeling of ‘it's too loud,’” but also, better gear plays quieter better.
    I do find that, ordinarily, what sounds “too loud” when I first sit down, doesn’t after about 3 or 4 songs and I start nudging things up a a click or two. Whether it just takes some time to re-acclimate or get “into it,” that happens almost every time for me.
    Brian
    bcwsrt wrote: »
    That's normal. Your ears get adjusted to the new (or new normal) Db level. The science behind that gets deep.
    bcwsrt wrote: »
    ...better gear plays quieter better...
    Totally agree here.
  • Joey_V
    Joey_V Posts: 8,600
    Yeah. 50 on arc Ref 10 is about 102-106 db at listening. That’s about 13 feet from speaker baffle.
    I went to the bass section of the Magico and it was pumping some serious air. Like you could feel it with the palm of your hand.
    I felt like I could push it some more because it still sounded clean but I didn’t want to risk it for no biscuit.
    That's loud, Joey! Holy moly. 50 on my Canary is 92Db"ish"......of course, this completely depends on the recording selection that I am listening too. +- 10-15Db, I would guess off the top of my head...
    I am at 10.3 feet away at the moment.
    If you don't mind me asking an off topic question, what are the dimensions of your listening room?
    Revisiting this...
    OMG. The volume is truly everything.
    From Infected Mushroons to classical.
    So, I had an editor for an online rag come over today and listen. I had demo tracks ready for him, volume matched to the system/room and what did he do?
    He wanted me to turn it up to ungodly levels. Yes, there was more visceral impact but he lost the essence of the music. The room was so overloaded that it masked so many things that are vital to critical listening. Whatever.
    I ended up giving him the remote and telling him to play whatever track at whatever listening level he wanted to play at.
    I am sorry but unamplified guitars should not be represented at levels that are.....well? Amplified.
    They should be at the level at which they are playing within the room.
    Maybe I am off here from the norm and I honestly don't care but I still say that the correct volume can make a selection okay, horrible or spot the F on.
    VR3 Posts: 29,455
    edited December 2024
    So having worked in a music store for almost a decade, I looked up the average volume of an unamplified acoustic guitar played in a venue setting. The average peaks are upwards of 95db...
    Which is also pretty loud!
    https://instrumentinsight.com/how-loud-is-an-acoustic-guitar/
  • Joey_V
    Joey_V Posts: 8,600
    Sometimes I question what these reviewers really hear…
    Sorry, Trey....you know full well I loves ya' broskizzle but that's laughable.
    The measurements (maybe) could have been off as much as our phone SPL levels (you know we have the same phones). Then there is the weighting....that you may not have even known about back then.
    If you measure at 1 foot away? That's one thing. If you measure, as if an unamplified guitar was playing from a distance of 10 to 12 feet away?
    VR3 Posts: 29,455
    Tom, it is definitely not laughable my friend.
    You put a full body acoustic guitar in the hands of a capable musician trying to fill a venue with sound, I assure you A weighted peaks will hit 95db.
    I listened to guitars/drums, etc etc for many, many many hours!
    Snare drum peaks at 125 to 130db.
    But most "passive/acoustic" instruments - woodwinds, brasswinds, acoustic guitars, drums can easily produce levels 85 to 120db unamplified.
