You’re doing it wrong…
1…1314161819…132
    mhardy6647 Posts: 35,562
    treitz3 wrote: »
    No truck deserves that.
    Well... it is a Chebbie.
    ;)B):blush:
    Viking64 Posts: 7,811
    I bet it rides . . . . like a rock.
    F1nut Posts: 52,406
    treitz3 wrote: »
    Dear lawd gawd....NO!!!
    Those are temporary wheels used by body shops, etc.
  • Unknown
    edited October 2023
  • daddyjt
    daddyjt Posts: 3,257
    ― Aleksandr Solzhenitsyn
  • halo71
    halo71 Posts: 4,645
    Exactly! I was about to post the same thing.
    --Gary--
    That is ingenious
    Not the adjective I'd have chosen... but... yeah. :p
    Safety first! I think they should've Plastidipped those safety pins before installation, don't you? I mean... I'm not sure they qualify as safety pins in this use case. B)
  • machone
    machone Posts: 1,588
    It's fine, it's only 18 watts.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    machone wrote: »
    Sounds like the kind of rationale used by more than a couple of the recent horde of Polk Audio "restomod" DIYers that have popped up 'round here recently... :#
    F1nut Posts: 52,406
    machone wrote: »
    BINGO!!!
    msg Posts: 10,650
    Toolfan66 wrote: »
    Turns out it was left-hand threaded...
  • tonyp063
    tonyp063 Posts: 1,156
  • daddyjt
    msg Posts: 10,650
    frighteningly great idea you mean.
    wait, is that a gas tank? (I keed, I keed)
  • motorstereo
    motorstereo Posts: 2,427
  • Willow
    Willow Posts: 11,364
    I like how they added the 2 decorative posts, giving the illusion they are helping to hold it up
    They put the can't in cantilevered.
    Frank Lloyd Wright would be proud.
    Yes, but would he be Taliesin proud?
  • boston1450
    boston1450 Posts: 7,758
    Those waterfalls are BEAUTIFUL. I'd live in that shack :D
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • aprazer402
    aprazer402 Posts: 3,463
    Maybe they're not doing it wrong.
    audioluvr Posts: 6,079
    Hey if they can find a buyer I'm hiring him!
    TV + sewage pipe = performance art
