Radial resistors
Answers
  • toolbelt
    toolbelt Posts: 124
    Mills...brighter? LOL
    It's hard to say as I also replaced (upgraded?) with Dayton tweeters. They seem to have the same top end, but handle the midranges slightly better, imo.
    Polk RTIA3 Fronts
    Polk CSIA4 Center
    Polk PSW Sub
    Pioneer VSX-521-K AVR
    And a friendly Labrador Retriever
  • invalid
    invalid Posts: 1,514
    How did the Mills resistors make yours speakers sound brighter, when the scientific evidence should be to the contrary?
  • toolbelt
    toolbelt Posts: 124
    Clipdat wrote: »
    Nah bro, placebo effect, you're full of ****. All resistors sound the same.
    Only guessing here, but I would think CAPs have an even greater effect on sound, than resistors?
    Polk RTIA3 Fronts
    Polk CSIA4 Center
    Polk PSW Sub
    F1nut Posts: 51,941
    toolbelt wrote: »
    Clipdat wrote: »
    Exactly
    F1nut Posts: 51,941
    ChrisD06 wrote: »
    Yeah my M5JR+ got brighter, whether it was with the SL2000 or the RD0198, after putting in the Mills resistors.
    The RD0198-1 is the wrong tweeter for those speakers.
    Mills and other high quality resistors are not as noisy, so the sound is cleaner, but cleaner isn't brighter unless the better resistors are exposing issues upstream.
  • ChrisD06
    ChrisD06 Posts: 929
    ChrisD06 wrote: »
    I did the TL mod (I rebuilt crossover to Series 2 specs). It shouldn't have made anything brighter as it was just a cap bump (which would lower tweeter XO point) so my guess, like I mentioned, is that my poly switches were tripped which is definitely it because the treble was super dull compared to my RT3000p. Now it's brighter. My only guess is that the DCR of the inductor is slightly higher on the Series 2 but it's a colorful brightness so I actually like it.
    My gear:
    • TCL 75QM7K TV
    • Onyko TX-NR656 AVR
    • RT3000p Fronts
    • CS1000p Center
    • RT35 Side Surrounds
    • RT35 Rear Surrounds
    F1nut Posts: 51,941
    So, you replaced the 12uF with a 13.5uF?
  • Gardenstater
    Gardenstater Posts: 4,801
    edited October 2023
    ChrisD06 wrote: »
    ChrisD06 wrote: »
    It's a contour network, not a "cap bump". That combination of R in parallel with C is when you have a trailing off response with increasing frequency, to correct that. So in a sense it does make things brighter, compared to if it was just a resistor.
    Oh sorry. You didn't do the TL "mod" per se. You did the built from scratch crossover that Polk came up with for the Series II.
    Nevermind.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • ChrisD06
    ChrisD06 Posts: 929
    13.6uF, yes. I ran two ClarityCap PX 250V 6.8uF caps in parallel.
    My gear:
    • TCL 75QM7K TV
    • RT3000p Fronts
    • CS1000p Center
    pitdogg2 Posts: 27,220
    erospbo reported
