I'm having the exact same issue as a previous post.
bobohansen1980
bobohansen1980 Posts: 1
edited October 2023 in Troubleshooting
I have the exact same issue as a previous post.
"Hi
I purchased POLK MagniFI Max system in December. Ive just started having problems. The sound bar will not stay on. I have un plugged it all & re started it. The bar comes on, orange light comes on & then 4 white dots come on then back to 1 orange light & then turns off. There is no sound. The sound bar does not stay on long enough to have sound. At 5 months old this should not be happening. I have looked at ifixit & it says replace motherboard. Where do I buy a new motherboard"
How can I fix this issue?
Mine is 10 months old and I wold really hope that polk makes a longer lasting product than that.
Sounded great when it worked
Answers
    F1nut Posts: 52,144
    Call Polk Customer Service
