Radial resistors
What is everybody replacing radial resistors with? I need a 5W 2.5 ohm radial resistor or similar preferably for a Polk crossover. v4x7ptfvrxt8.jpg
Polk RTIA3 Fronts
Polk CSIA4 Center
Polk PSW Sub
Pioneer VSX-521-K AVR
And a friendly Labrador Retriever
Answers
  • Just use a 12W Vishay/Mills and mount it vertically if you so desire. The leads that are supplied are probably long enough for the upper end to still be soldered into PCB.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • pitdogg2 wrote: »
    Unfortunately, 2 of those to Canada, will run about $75+. I can't really justify that additional expense for small bookshelf speakers that are 20 yrs old which I purchased as demo units for $100.
    Polk RTIA3 Fronts
    Polk CSIA4 Center
    Polk PSW Sub
    mhardy6647 Posts: 35,049
    toolbelt wrote: »
    Does PartsConnexion sell the resistors you want?
    They're as Canadian as... well... some would say maple syrup, but, since I am in Northern New England, I'd never say that. ;)
    https://partsconnexion.com/
  • mhardy6647 wrote: »
    toolbelt wrote: »
    Unfortunately they don't list the exact same ohmage. They have 2.7 Ohm, but I'm trying not to alter component values. Not sure if 2.5 ohm was an oddball value out in the world. I've come across multiple listings of radial style (per OE Polk) in higher and lower values running in the $1.72 range.
    Polk RTIA3 Fronts
    Polk CSIA4 Center
    Polk PSW Sub
  • George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • Awesome. They're actually only about 30 mins away from me and offer a pick up option. Just confirming that its ok to bend the leads (being careful not to bend them near the ceramic body)? Can hot glue be used near them, or do they get hot and just melt the glue?
    Polk RTIA3 Fronts
    Polk CSIA4 Center
    Polk PSW Sub
  • You don't ever want to use hotmelt glue or anything else that would reduce convection/conduction of heat from the resistor. Yeah just put a pair of needle nose or hemostats on the lead near the body and bend against that to not stress the point of exit. Probably more of an issue for caps though.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • looks like the leads are about 1/4" longer than the body so i'll have to bend it fairly close to the body in order to reach the board with the top lead. Is it ok to solder the leads fairly close to the body, as the bottom end of the body will need to be touching the board for mounting upright?
    Polk RTIA3 Fronts
    Polk CSIA4 Center
    Polk PSW Sub
  • Yep you'll have to. If you have room, try clipping a pair of hemostats to the lead as a heatsink while soldering.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    edited October 2023
    One may also add "pigtails"* if needed to extend the length of the leads. :#
    I -- ahem -- keep a pill bottle full of offcuts of component leads for just such puposes. Not that I'd admit that just anywhere.
    *They're called "pigtails" because, for best results, one (or both) leads in the "splice" are tightly twisted together a few times, then soldered. B) Back in the old days, e.g., Sprague (now SBE) capacitors used to include little solder-saturated "springs" for capacitor replacement using "orange drops". This is a classic trick for doing point to point re-work. One may cut the old component out, leaving a useable length of the old leads still connected to the circuit, then attach the new component to the stubs. Yes, it is a bit "low rent" but it is a viable (and time-honored) service technique, which I learned from a old service person (to whom I was quite closely related) ;)
    The act of soldering one joint will not melt the other, as long as one is reasonably adept at soldering.
  • Gardenstater
    Gardenstater Posts: 4,785
    If I ever attempt a point to point crossover I'm going to try 4N copper crimping sleeves to minimize the solder used.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • toolbelt
    toolbelt Posts: 124
    So I should try my soldering iron rather than using my plumber's torch then? :D
    Polk RTIA3 Fronts
    Polk CSIA4 Center
    Polk PSW Sub
    F1nut Posts: 51,798
    Use Cardas Quad Eutectic solder, you'll thank me later.
  • invalid
    invalid Posts: 1,461
    It's a more money but well worth it.
  • toolbelt
    toolbelt Posts: 124
    Well I went to PC today and instead of MRA12's, he suggested MRA5's instead. And while the price differ was negligible, my original intent was to restore, not upgrade these speakers. The leads on these are plenty long enough to mount vertically. Switching from a generic Polk resistor to Mills could be considered an upgrade in itself, even though the wattage and resistance are the same. He surmised my tweeters shorted, causing the resistors to blow. As I'm replacing the tweeters with new Daytons, oe spec branded resistors are sufficient enough. The tweeters in both speakers were shot, as were the same resistors on both boards. The other resistor is still perfectly in spec on both speakers. If these were my daily speakers and not just backups for my backups (neither of which I have a need for), I likely would have done a full upgrade. This was more of a learning experience.
    Polk RTIA3 Fronts
    Polk CSIA4 Center
    Polk PSW Sub
  • toolbelt
    toolbelt Posts: 124
    Well all installed and readings checked. Comments/opinions? s263kfrm430s.jpg
    Polk RTIA3 Fronts
    Polk CSIA4 Center
    Polk PSW Sub
  • ChrisD06
    ChrisD06 Posts: 927
    Very good solder work, just clean your flux with 99% isopropyl alcohol and a soft bristle toothbrush and some q-tips.
    The resistor has good breathing room so it'll stay cool. Nice bends too.
    Personally, I'd replace the other resistors as Mills resistors seem brighter in my opinion and you might notice some sonic differences which could bother you. If you don't notice the differences then don't bother.
    My gear:
    • TCL 75QM7K TV
    • Onyko TX-NR656 AVR
    • RT3000p Fronts
    • CS1000p Center
    • RT35 Side Surrounds
    • RT35 Rear Surrounds
  • toolbelt
    toolbelt Posts: 124
    ChrisD06 wrote: »
    The flux in the picture is Polk's, not mine. lol As for the bends, the loops were determined by the lengths required in order to reach back to the board, while still maintaining some breathing room off the board. I would have preferred slightly longer leads but they did the job. At this point, the speakers are back in service for now, but I'll be putting them on a shelf in the basement along with my temporary replacement XT15's (which I'm passively trying to sell) and switching back to my new (used) RTIA3's. While I was at it, I refoamed my CV U-12's, which have also been taking up space in my basement for almost 30 years. lol
    Polk RTIA3 Fronts
    Polk CSIA4 Center
    Polk PSW Sub
  • ChrisD06
    ChrisD06 Posts: 927
    toolbelt wrote: »
    ChrisD06 wrote: »
    Sounds like you've been bitten by the audio bug. Welcome to the club lol.
    My gear:
    • TCL 75QM7K TV
    • RT3000p Fronts
    • CS1000p Center
    F1nut Posts: 51,798
    Mills...brighter? LOL
  • invalid
    edited October 2023
    Isn't this the same guy that can't hear a difference with better cables?
    Post edited by invalid on
    pitdogg2 Posts: 27,072
    invalid wrote: »
    Fixed it
  • invalid
    invalid wrote: »
    Fixed it
  • ChrisD06
    ChrisD06 Posts: 927
    Yeah my M5JR+ got brighter, whether it was with the SL2000 or the RD0198, after putting in the Mills resistors.
    My gear:
    • TCL 75QM7K TV
    • RT3000p Fronts
    • CS1000p Center
    Clipdat Posts: 13,095
    Nah bro, placebo effect, you're full of ****. All resistors sound the same.
  • bcwsrt
    bcwsrt Posts: 2,416
    Shouldn’t you be in class today?
    Brian
  • ChrisD06
    ChrisD06 Posts: 927
    Clipdat wrote: »
    To quote dbe from Parts-Express forum: "The difference in resistor is a simple, verifiable one. It boils down to TCR in the resistor. A standard resistor has a TCR in the 500-1000 ppm and a Mills is 20 ppm. This equates to less HF hash around cymbals and other steep transients. The easy way to tell without burning your brain up is in extended listening tests where the degree of listening fatigue is the clue to untrained listeners. A trained listener will pick a Mills out 10/10 in A/B/X."
    So the Mills have an actual measurable scientific difference. Also it appears that because of this, I was definitely tripping or my old resistors managed to gain impedance due to heat degradation...
    ...or, what just popped in my head now, the polyswitches were tripped (this is definitely it lol) and I forgot they even existed in the first place. I'll have to do a proper test with my RT3000p when I rebuild them next summer.
    My gear:
    • TCL 75QM7K TV
    • RT3000p Fronts
    • CS1000p Center
    Clipdat wrote: »
    They're usually pretty quiet.
    I guess if you put a whole bunch in a paper bag and gave 'em a good shake -- they'd kinda rustle.
  • toolbelt
    toolbelt Posts: 124
    edited October 2023
    ChrisD06 wrote: »
    toolbelt wrote: »
    ChrisD06 wrote: »
    I knew you were going to mention that as you warned me previously, but I suspect my sudden interest will go dormant again until something else blows up, likely in another 20+ years, although I do have plans for a proper HT setup in my basement, which I completely refinished just 2+ years ago for my daughter, who has since rented a house with her BF 75 miles away. I had to modify my previously built HT infrastructure which I built almost 30 yrs ago when a 32" tv was considered SOTA. They had their tv and fireplace mounted on it so I just need to add my own equipment at some point in the future. c5vk8em0y5wz.jpg
    Polk RTIA3 Fronts
    Polk CSIA4 Center
    Polk PSW Sub
