velodyne or polk
  • juice21
    juice21 Posts: 1,866
    edited May 2002
    HSU research vtf-2
    i am currently running two, and am very pleased...:D
  • joe logston
    joe logston Posts: 882
    edited May 2002
    hi gplracer wecome to the forum, i thought of changing my audio sorce 15" sub , with a svs for a placement sub, i wish there was a place i can listen to one in las vegas.
    thanks
    . rt-7 mains
    rt-20p surounds
    cs-400i front center
    cs-350 ls rear center
    2 energy take 5, efects
    2- psw-650 , subs
    1- 15" audiosource sub
    lets all go to the next ces.
  • TroyD
    TroyD Posts: 13,124
    edited May 2002
    Who would really need a sub that would put out 120db at 20Hz??
    If you are listening to stuff that loud, you won't be listening to anything shortly.
    I'm all for good bass and all but I believe that some of this is overkill.....
    BDT
  • MxStYlEpOlKmAn
    MxStYlEpOlKmAn Posts: 2,116
    edited May 2002
    M&K makes awesome subs...with dual 12 inch drivers, for only 1500.....it can shake a whole house!
    Damn you all, damn you all to hell.......
    I promised myself
    Damn you all! - ATC
  • gplracer
    gplracer Posts: 36
    edited May 2002
    Orangetoupe have you ever heard a svs sub? There are subs out there that would probably be better but none that are in the price range of the svs with the exception of the HSU. I hear it is a great sub too! Check out this review:
    Sub comparison
    Also if you want to hear some SVS subs or other types of speakers try this:
    Audio Envy
    It is site where people sign up to let you know you can come by and listen to their equipment.
  • Ron-P
    Ron-P Posts: 8,520
    edited May 2002
    Ever thought about building your own? You can achieve the same results as an SVS for half the cost. It is very easy is you have some basic wood-working skills.
    Peace Out~:D
    If...
    Ron loves a film = don't even rent.
  • gplracer
    gplracer Posts: 36
    edited May 2002
    I really did think about it. I think you could build one that would surpass the SVS and the HSU. It would have to be larger though. Most people use the sonotubes. They are the cardboard molds for concrete columns.
  • Ron-P
    Ron-P Posts: 8,520
    edited May 2002
    Yep, that's what I used.
    Peace Out~:D
    If...
  • gidrah
    gidrah Posts: 3,049
    edited May 2002
    I don't think he's in the market for a $1500 sub. If he was, I'd suggest a EdgarHorn sub seismic. You can get a no finish sub at this price that'll kill. Hits deep, fast and very musical. People will wonder what it is as they feel their chest concave. :eek:
    I'm with Ron on this one!
    Make it Funky! :)
  • gplracer
    gplracer Posts: 36
    edited May 2002
    Well I guess it depends on whether or not he want to build one or not. SVS has a new model that is supposed to be good. Although I have not heard one. It is $549. It comes with an amp built in. Here is the link:
    SVS PCI Sub
  • goingganzo
    goingganzo Posts: 2,793
    edited May 2002
    sorry for the dubble post
  • goingganzo
    edited May 2002
    you can allmost buld 2 for that price and you can make it allmost the same size as the svs or you can buld it any way you want you can even make a cofie tabble out of it nice sub ron what did you use to get the grey on the wood?
