RTi6 & RTi4 Rubber Surrounds
Keiko
Keiko Posts: 794
Asking for an opinion concerning the rubber surrounds and dust caps on these models. A few months ago I had to replace the dust caps on my RTI6's because the rubber had completely dried out and crumbled to the touch.
Anyway, the surrounds are intact, but don't feel as supple when I first got them. Same with my 4s. So, my question is this, is it safe to use something like Armor All Protectant on the surrounds and dust caps of the speakers? I could replace them and customer support has advised me that replacement speakers run at $60.00 bucks a pop for the drivers. Not too bad, but funds I don't have in our budget right now. Anyway, just trying to preserve what I got and trying to make it last. If anyone knows of a better product for this purpose, hit me.
TIA,
Mike
    F1nut Posts: 52,007
    Jstas can probably recommend something. Armor All isn't it.
  • Keiko
    Keiko Posts: 794
    Thanks Jesse, I'll send him a PM.
    xschop Posts: 5,413
    On the vintage butyl surrounds, Ive been using wintergreen oil cut down to 70% by isopropyl alc. Works great to soften them back from dry-aging.
  • Keiko
    Keiko Posts: 794
    edited August 2023
    xschop wrote: »
    Thanks chopper. Do you have a link to the product and how you're using it?
    xschop Posts: 5,413
    edited August 2023
    You can use any 100% pure essential oil product. It only takes a couple mL to do a pair of MW's using a small brush to apply after dilution of isopropyl alc. Apply a wet sheen then simply let air-dry.
    https://www.amazon.com/Artizen-Wintergreen-Essential-100-NATURAL/dp/B06Y2H5C3D/ref=mp_s_a_1_19_maf_2?crid=3DBJMBK413483&keywords=w intergreen+oil&qid=1692955953&sprefix=wintergreen+oil%2Caps%2C188&sr=8-19
  • ChrisD06
    ChrisD06 Posts: 929
    The dust caps on the drivers cracking appears really common on the RTi series...
    You folks wouldn't know if this affects the RTxxxp series now, would you?
    My gear:
    • TCL 75QM7K TV
    • Onyko TX-NR656 AVR
    • RT3000p Fronts
    • CS1000p Center
    • RT35 Side Surrounds
    • RT35 Rear Surrounds
    F1nut Posts: 52,007
    Isopropanol (IPA) is widely used as a drying solvent and cleaning agent. A drying solvent is not something one should apply to butyl rubber.
  • bcwsrt
    bcwsrt Posts: 2,512
    I'd be interested in what @Jstas recommends, as well.
    Brian
    xschop Posts: 5,413
    Can you explain that science?
    F1nut Posts: 52,007
    xschop wrote: »
    Really...LOL
    xschop Posts: 5,413
    Really. Is it the solvent or solute in this application? And why?
    F1nut Posts: 52,007
    Exposing rubber to rubbing alcohol infrequently can cause discoloration and deterioration, but prolonged use of isopropyl alcohol will wear down and eventually destroy it.
    'Nuff said.
    xschop Posts: 5,413
    Rubber referred to there is latex. Butyl is not latex. You still haven't answered the basic question. Solute or solvent in this application, Bill Nye?
    F1nut Posts: 52,007
    No, it refers to rubber. Latex is actually pretty resistant to isopropyl.
    xschop Posts: 5,413
    Little dodgy today, chief.
    F1nut Posts: 52,007
    You can keep ignoring the facts, but it isn't a good reflection on you.
  • Gardenstater
    Gardenstater Posts: 4,804
    edited August 2023
    It's pretty easy to look up chemical compatibility of rubbers and other materials: 1 is the highest rating in this chart.
    And:
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    xschop Posts: 5,413
    ^^^Facts are hard to embrace nowadays^^^
    F1nut Posts: 52,007
    xschop wrote: »
    You'd know all about that.
  • Keiko
    Keiko Posts: 794
    WoW! Lots of comments @0930hrs as I wake up reading this thread. And yeah, I thought about the use of alcohol on the surrounds and to be honest, I'm reluctant to go with that. I won't even use alcohol based cleaners on my records. Nothing personal xchop. I'm going to wait on John's recommendation since he's very knowledgeable in this area. If he gives the GO on this method then I'll reconsider.
    Aloha B)
  • Gardenstater
    edited August 2023
    Isopropyl Alcohol is OK for continuous contact in an O-ring seal. It couldn't possibly deteriorate a surround where it is free to evaporate in pretty short order.
    Methyl Salicylate is "Fair" or "Minor to Moderate Effect", so go easy on the quantity as I believe xschop suggested. I wouldn't submerge it in the stuff by any means:
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    xschop Posts: 5,413
    Keiko wrote: »
    Aloha B)
    I'll let nutter off the hook, since he didn't answer, but gaslight.
    In this application the 50\50 mix of 70% isopropyl alc. to wintergreen oil renders it the solute by standard chemistry definition. In layman's terms it just thins the oil. No chemical reaction/attack occurs during the 15-20 min drying process as the methyl salicylate infuses into the butyl rubber, softening it.
    Stoichiometry is not part of the woke science today.
    I've done this to quite a few MW's now and have only seen good results.
  • Keiko
    Keiko Posts: 794
    I just read a thread on audiogon and this is what Albert Von Schweikert recommends.
    https://www.parts-express.com/CAIG-RBR100L-25C-Rubber-Cleaner-and-Rejuvenator-25mL-341-287?quantity=1
    PDF is here: https://www.parts-express.com/pedocs/more-info/341-287--caig-rbr100l-25c-msds.pdf
    audiogon thread is here: https://forum.audiogon.com/discussions/treatment-for-rubber-speaker-surrounds
    I'm still going to wait on Jstas to get back to me. When I replaced the dust caps on my 6's his advice and expertise was solid and appreciated.
  • Gardenstater
    No disrespect to Albert but I would be reticent to try that since a main ingredient is Mineral Oil and that is not recommended for Butyl Rubber.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • Keiko
    Keiko Posts: 794
    Noted and thank you. And Keiko thanks everyone for their input.
    F1nut Posts: 52,007
    xschop wrote: »
    Keiko wrote: »
    Aloha B)
    No need to answer your pointless question.
    Good results...LOL. How many years has your slurry been on them?
    xschop Posts: 5,413
    xschop wrote: »
    Keiko wrote: »
    Aloha B)
    Long enough to ameliorate the dry-rot.😉
  • Keiko
    Keiko Posts: 794
    xschop wrote: »
    Won't ship to Hawaii, bastages! >:)
    xschop Posts: 5,413
    Jeff Bezos and Oprah will hand deliver once they've closed on all the firesales there.
    F1nut Posts: 52,007
    xschop wrote: »
    xschop wrote: »
    Keiko wrote: »
    Aloha B)
    So, a few days then. Got ya.
