B&O CX100 crossover enigma
Send me the midranges, I'll plug 'em and paint them neon orange if you'd like.Don't take experimental gene therapies from known eugenicists.
I don't have any YET lol, that's why I mentioned I wish I had them.
This is an offer I will take up if I ever find some. -
Round 2....
Don't take experimental gene therapies from known eugenicists. -
Made a set of snub-nose phase plugs for these mid ranges and installed another set of Clarity PX caps with new internal wiring....
The black anodizing on this particular set was damaged by previous owner, so I’ll make them with the brushed alloy patina… Over the years I’ve used NaOH solutions, but have found heavy duty oven cleaner works great with 2 applications…
The other midrange coil was fried, so I unwound a 25.5mm ID 6.5ohm coil down to 5.2ohm to match the other midrange driver. Cut to 0.950″ total length with 0.44″ coil length to match as well. Glued in and set with shims leaving wires close to ferrule attachment points for soldering….
Post edited by xschop onDon't take experimental gene therapies from known eugenicists. -
Tired of the foam I had under them to angle up at the desk....
