One Stroke Engine Technology
audioluvr
Found this interesting. All I know is EV' s will not sustain the human race.
https://interestingengineering.com/transportation/innengines-e-rex-motor-1-stroke-engine-technology
so, with the BIG DISCLAIMER that I know
nothing
about this (!)
I did read an interesting response to a post about it over at AK...
(i.e., I absolutely cannot evaluate the accuracy of the reply, but it certainly caught my eye)
https://audiokarma.org/forums/index.php?threads/120-hp-from-an-85-pound-500cc-engine.1035020/#post-16522012
YMMV, though, of course, as they say
I think and I may be wrong the idea is a range extender for an ev, kind of like a hybrid.
I drive a prius and I can say the technology works very well.
I go about 480 miles on 9 gallons on average.
No complaints- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Indeed. Mrs. H was an early hybrid adopter and loved hers (although she went I/C when she last bought a new car 'cause at the time there were no medium sized hybrids that she liked).I think and I may be wrong the idea is a range extender for an ev, kind of like a hybrid.
No complaints
A 4-stroke works fine for that, though
The NLA Chevy Volt and the plug-in Prius and its kin were/are the best of both worlds, arguably.
Interesting engine design, but it has limitations AND, its is in absolutely no way a 1-stroke engine! It is a two stroke. No, it doesn't need mix gas, but it is still 2-strokes. Intake/compression and combustion/exhaust. The design probably has some friction issues (8 cylinders vs 4), and it will be very low on torque, but it could be a compact/lightweight charging engine.
Regarding the "1 Stroke Engine" claim, I thought the same thing, that it was bogus. There are 2 power strokes per output shaft revolution. That is true. The same holds true for a 4 cycle, 4 cylinder engine. Their engine has each cylinder firing at some point during each revolution, which can't be said for the 4 cyl, 4 cycle. High power to weight ratio is where it's at, if it has longevity. I think their claim that it is very low vibration makes sense. Pretty cool really.Post edited by Gardenstater onGeorge / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
There is technically a true 1-stroke engine, it's called the rotary. A 1 stroke would mean the only stroke of the piston has the intake, compression, combustion, power, and exhaust. So essentially a piston moving down or up forever.
This does look like a really cool engine design though, I want to see how it performs in the real world usage.My gear:- TCL 75QM7K TV
- Onyko TX-NR656 AVR
- RT3000p Fronts
- CS1000p Center
- RT35 Side Surrounds
- RT35 Rear Surrounds
Ya, I saw that it was a 2 stroke and the squash plate design has its drawbacks like high friction resistance and low torque yield but at least people haven't given up on the ICE
One note on the design flaw is it doesn't show how to keep the pistons from overextending and crashing into one another.Gustard X26 Pro DAC
I'm really curious to know how it limits TDC of the piston. Furthermore, how easy are these to work on? I can see these being a massive challenge for mechanics, sort of like the rotary was (though admittedly it's a simple design, it was just so different it took adjusting to)
This is a whole different mechanical beast.My gear:- TCL 75QM7K TV
- RT3000p Fronts
- CS1000p Center
Cylinder pressure, under compression prior to ignition and during combustion.George / NJ
iFi nano iDSD DAC
iPurifier3
Gardenstater wrote: »Cylinder pressure, under compression prior to ignition and during combustion.
That wouldn't limit how far they can extend, if the pressure got too high somehow, it'd just leak past the piston rings into the crankcase.
There needs to be a mechanical prevention put in place, else the pistons would smash into each other due to backpressure in the crankcase rapidly decompressing.My gear:- TCL 75QM7K TV
- RT3000p Fronts
- CS1000p Center
The pressure in the cylinder banks is what keeps the roller bearing firmly against the squash plate during compression and during combustion stroke it not only maintains contact but drives it's rotation. If something were to go wrong with the air induction maybe there could be a failure where the pistons could contact but that would be a catastrophic failure of the engine.
https://www.youtube.com/watch?v=-evhsWLWlkY&t=116s
George / NJ
iFi nano iDSD DAC
iPurifier3
Gardenstater wrote: »The pressure in the cylinder banks is what keeps the roller bearing firmly against the squash plate during compression and during combustion stroke it not only maintains contact but drives it's rotation. If something were to go wrong with the air induction maybe there could be a failure where the pistons could contact but that would be a catastrophic failure of the engine.
Hmmm, it WOULD be a cool design if the pistons used pressure to determine how far back and forward they can go. In the combustion chamber it'd prevent them from smashing, in the crankcase (well, whatever it is with this design) it would prevent them from just shooting out of the cylinder.
Very interesting design so far nonethelessMy gear:- TCL 75QM7K TV
- RT3000p Fronts
- CS1000p Center
I read something about variable compression ratio through control of the valvetrain. It would be interesting to get ahold of their patent, when it is granted or if it is already granted. I think the video shows that the pistons do not "smash".George / NJ
iFi nano iDSD DAC
iPurifier3
This video shows that there is another squash plate that defines a channel with the main one, and the piston bearings are forced to ride in that channel.
https://www.youtube.com/watch?v=gqc0KZRKreE George / NJ
iFi nano iDSD DAC
iPurifier3
Super interesting.
Now I want to see the patent, tooMy gear:- TCL 75QM7K TV
- RT3000p Fronts
- CS1000p Center
A little bit of a deep dive into the engine, if you can handle the accent...
https://www.youtube.com/watch?v=9I0_3qFmPUM -
Looks like the design would have a very high combustion efficiency and would allow you to run gas or diesel all with very few moving parts. Maybe an 8 cylinder version wouldn't sound like a lawnmower with a straight pipe?Gustard X26 Pro DAC
Here is the US patent:
https://worldwide.espacenet.com/patent/search/family/049517517/publication/US10267225B2
George / NJ
iFi nano iDSD DAC
iPurifier3
