Ordered a SVS 3000 Micro today
Milito
Milito Posts: 2,003
Since I got my L600's I really don't have room for a standard size sub so I ordered the above. I hope it will have enough output for our open concept room. I'll let everyone know what I think of it after I receive it and get some hours on it.
  • chrispyfur
    chrispyfur Posts: 170
    It's very well reviewed, I'm sure you'll enjoy it a lot!
  • bcwsrt
    bcwsrt Posts: 2,492
    I just recently added two REL T/5x subs. Each has an 8" down-firing driver. They fill my mostly open basement quite nicely. I'll be surprised if that unit doesn't get the job done for you. Look forward to hearing about it.
    Brian
  • mantis
    mantis Posts: 17,557
    Open rooms are very hard to get bass right. Especially with just 1 woofer. You can however make 1 seat good and the rest not so good so don't expect to sit in different places and get the same results. Once you dial in this sub, down the road you want to add another one.
    The 3000 is supposed to be a great little performer, I have no experience with it just want I read and watched on it.
    Dan
  • Emlyn
    Emlyn Posts: 4,814
    They're small enough to get two for most rooms. B)
  • Milito
    Milito Posts: 2,003
    edited July 2023
    I'm going to put it on the left side of my left speaker as that's the only place I can put a sub. Not enough room on the right side and the wife wouldn't go for that. It's our main room and it's taken me awhile to talk her into letting me get one and she only agreed because it's small. If it doesn't work good I'll send it back.
  • jbreezy5
    jbreezy5 Posts: 1,141
    Milito wrote: »
    That MF integrated appears to be putting some strain on the shelf. Might be worth considering reinforcing it with a metal support bracket. Should just require some screws.
  • Milito
    Milito Posts: 2,003
    Yes I need to do something about that. Thanks.
  • chrispyfur
    How do you like the L600s?
  • mantis
    The Musical Fidelity is a beast, do you ru yours in Home theater Bypass? Thats how I run mine
    Dan
  • mrloren
    mrloren Posts: 2,474
    Milito wrote: »
    Yeah, WAF does crimp on the HT setup, good luck
  • dpowell
    dpowell Posts: 3,081
    Congrats on the purchase! Keep us posted on how it performs.
    msg Posts: 10,460
    edited July 2023
    Milito wrote: »
    A piece of MDF should sort that.
    Does the Micro have the DSP, Room Correction and app control or remote control?
    These types of features were game changers for me where subs are concerned.
    I'm good with a set crossover point, but having volume control makes a huge difference in the listening experience, especially if streaming and regularly changing artists, albums, or genres.
  • Milito
    Milito Posts: 2,003
    edited July 2023
  • Emlyn
    Emlyn Posts: 4,814
    Right, line level plus LFE inputs and the full DSP app make it very flexible for two channel or home theater. No speaker level inputs but that's not that subwoofer's purpose. Should fill out the bottom end nicely from the corner and different configurations can be set for music and home theater if desired.
  • Milito
    Milito Posts: 2,003
    chrispyfur wrote: »
    Myself and some others here have purchased them. Use the search function to find the reviews.
    I like them.
    msg Posts: 10,460
    Milito wrote: »
    Wow, that looks great!
    Did you get it yet?
    The answer is yes.
    Now where is the first impression post?
    msg Posts: 10,460
    It's been nearly an hour with no response to my last. I'm now convinced that @Milito Mike was just making all this up just to get attention.
    VR3 Posts: 29,540
    Came for pics... Leaving disappointed
    pitdogg2 Posts: 27,257
  • Milito
    Milito Posts: 2,003
    Got it in late today, but had plans for the night. I will hook it up tomorrow and post some pics.
    msg Posts: 10,460
    Nice! Curious to hear how it goes a you get settled with it. I really like these little subs.
    I was finally able to find a Sunfire True Sub Super Junior a couple of years ago. Similar form factor as your SVS, but the Sunfire is active/passive, not dual driver, and I've not found them to work all that well in larger spaces, unlike how SVS advertises the Micro. For SoHo, the Sunfire pairs really well with Audioengine HD3s. I have it sitting on a small IsoAcoustics stand.
    I've been curious about this SVS Micro since first saw mentioned here. It sure looks great on the site, and I'm completely sold on remote control and DSP and/or autocal tools for subs. Remote control is a game changer for the listening experience.
    So, do you have your Musical Fidelity set up in HT Bypass? And the sub is connected through the Yamaha, I presume?
    When you play music, is it through the MF, or through the Yamaha?
    I was surprised to learn that the HK 990 integrated I currently use supports sub output from the 990 while in HT Bypass. I have a music-first sub connected to the HK, and an earlier HSU VTF-15 connected to the Parasound C2 processor. When I'm in TV mode, I disable the sub on the HK. When I'm listening to music, I enable it, and the crossover's set at 55Hz with the Wharfedale Lintons I'm running right now. It's a pleasing combination, and I was surprised to be able to run at a lower crossover point, but it's pretty clean.
    Do you plan on trying to run the sub directly with the MF at all, for the benefit of the MF front end and sub?
  • Emlyn
    Emlyn Posts: 4,814
  • Milito
    Milito Posts: 2,003
    I have the Musical Fidelity set up in HT Bypass and the sub is connected through the Yamaha.
    I listen to music on my Flac USB stick with the Yamaha and listen to vinyl and streaming thru the MF.
    Will probably keep it setup the way I have it now.
    F1nut Posts: 51,962
    I highly recommend getting your sub off the ground and I recommend the Adona Multi-Element Cones to do so.
  • dpowell
    edited July 2023
    This is good advice. Getting the sub off the floor will tighten things up.
    VR3 Posts: 29,540
    Came back for pics, not disappointed!
    Looks great! Congrats!
  • Milito
    Milito Posts: 2,003
    Thanks, I was going to look into getting some spikes in the future for the sub.
  • machone
    machone Posts: 1,564
    I can't see the sub. Why is the pot in the way? :p
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • bcwsrt
    bcwsrt Posts: 2,492
    I’m glad she didn’t want the pot ON the sub.
    Brian
