Ordered a SVS 3000 Micro today
WAF may prevent taking this advice; however, Milito has one advantage to help with subwoofer placement issues, which is his use of YPAO calibration.
It seems to work very well for me in both systems with Yammy receivers. Sound is well-balanced top-to-bottom, and bass is tight, fast, punchy and deep.CD Players: Sony CDP-211; Sony DVP-S9000ES; Sony UDP-X800M2 (x2); Cambridge Audio CXC
Cables: Tripp-lite 14ga. PCs, Blue Jeans Cable ICs, Philips PXT1000 ICs; Kimber Kable DV30 coaxial ICs; Canare L-4E6S XLR ICs; Kimber Kable 8PR & 8TC speaker cables. -
Those will work. They are the same as the Dayton spikes at PE, except for the thread pattern.
I don't understand why so many subs come with those tiny short feet.
Some woofer manufacturers want their subs de-coupled but near as possible to the floor for boundary reinforcement. REL comes to mind as one that encourages corner loading for the same reason.CD Players: Sony CDP-211; Sony DVP-S9000ES; Sony UDP-X800M2 (x2); Cambridge Audio CXC
What is "boundary reinforcement"? Curious.
But yeah, some sub manufacturers use decoupling feet, like the SVS SoundPath. I think HSU has something similar.
I do wonder whether down-firing and forward-firing, or in this case dual-side firing makes a difference in whether coupling or decoupling is best suited.
I did notice for certain that elevating a down-firing MartinLogan Abyss reduced congestion and made for increased impact, bass note separation and hang & decay.
I have hard rubber feet for that sub, but currently have it on some Sound Addicted SubCone Isolation Feet; hard flooring. These are a little squishy, but not quite like Sorbothane.
https://www.amazon.com/gp/product/B09NLQZ8NV
I disabled signatures. -
Every REL sub I've seen has what appears to be 2 inch tall legs. -
@msg - boundary reinforcement simply means a speaker or subwoofer is located in closer proximity to a wall, floor, or corner.CD Players: Sony CDP-211; Sony DVP-S9000ES; Sony UDP-X800M2 (x2); Cambridge Audio CXC
The feet that came with my HT1003 are approx. 1/2” height.
Yep, those are the tiny feet. Seems they went to those on their HT subs.
The Rel HT series doesn't use a bottom mounted passive radiator like the other models that use either rails or substantial feet. The MKII version of the HT/1003 does use larger feet but possibly more for style. The HT/1510 model has the larger feet so the subwoofers can be stacked.
Regardless, raising the sub off the floor improves the performance.
Received my spikes I ordered today and got them installed. Cleared up the bass some, I'm pleased with them.
Had a friend over the other night who has some Salk speakers. He thought my setup sounded really good and really liked the output of my new sub.
Yamaha RX-A2070, Musical Fidelity M6si integrated amp, Benchmark Dac1, Bluesound NODE 2i, Audiolab 6000CDT CD Transport, Parasound Zphono USB Phono Preamp, Fluance RT85, Ortofon 2M Bronze, Polk L600's, L400, L900's, RC80i's, SVS 3000 Micro, Audioquest Interconnects and Digital Cables, Nordost Silver Shadow Digital Cable, Cullen Gold and Crossover Series Power Cables, Douglas Connection Alpha 12AWG OCC Speaker Cables, Douglas Connection Alpha Analog Interconnect Cables, Douglas Connection Alpha 11 OCC Custom Power Cable, Signal Power Cable, Furman PL-8C 15 Power Conditioner, Sony 65" 900F, Sony UBP-X700, Fios, Apple TV 4K, Audioquest Chocolate HDMI Cables. SnubWay, Main Stream -
Nice!
This is one sub I wouldn't touch myself. It's too small for living rooms!
I have a pb 1000 pro myself in a tiny bedroom!
How can you let your partner have a negative impact in home theater?
Can you ask her if she is happy to make it less good and enjoyable for you.
I hope she understands this is home theater and it's about quality audio and movie and TV show viewing.
You must be single.
Spoken like a true adolescent.“Human beings are born with different capacities. If they are free, they are not equal. And if they are equal, they are not free.”
― Aleksandr Solzhenitsyn -
I like my SVS 3000 for music, blending in with stand mounts.
It will be part of the downsize setup if...
I've yet to raise it up but this thread is the push I needed. Thanks!Speakers: Polk Lsim, ATC SCM19 v2, NHT SuperzeroSpeaker Cables: DH Labs, Transparent, Wireworld, Canare, Monster: Beer budget, Bose ears -
I am glad all my HT stuff is in the basement where she has no say, lol. I have a couple of SB 3000's for my main HT and they do HT and music extremely well. I really considered this sub, or a pair for my music only rig but decided to go with a pair if Rhythmic L12's instead. Glad you are liking it though.
Anyone on a crawl space should entertain infinite baffle... Takes up no floor space and for theater the bass is truly insane- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
What in the Roblox-playing 12 year old?My gear:- TCL 75QM7K TV
- Onyko TX-NR656 AVR
- RT3000p Fronts
- CS1000p Center
- RT35 Side Surrounds
- RT35 Rear Surrounds
You might be a redneck if ….🤣
I was and forever will be a redneck, but I haven’t had a crawl space in a very long time…😢Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Not sure how a crawl space correlates to being a redneck but sure
I have heard many subwoofers and absolutely nothing touches an infinite baffle for theater, nothing!
It has endless output and extension with literally no distortion
Foundation shifting bass and I have maybe 1500 invested into it- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
You know I’m just razzing you. that sounds frickin awesome and I would love to hear it! We can’t do crawl spaces in central Texas since the ground shifts too much. You end up with major foundation issues…but man it’s convenient for repairing pipers, running wires, etcLiving Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
I'm intruiged about an infinite baffle subwoofer... My rear wall of my theatre room vents into a storage space underneath the stairs and I suppose it'd be a good spot for it. My side wall vents into another room and the ceiling too.
I might have a spare 10" driver lying around, don't think I'd want to rip apart my walls though. Where would I even start lol.My gear:- TCL 75QM7K TV
- RT3000p Fronts
- CS1000p Center
Usually infinite baffle drivers have ultra long throw and heavier cones.
You also need an incredibly large space like a crawl space or an attic
My 4 x 15s in the crawl displace enough air to displace all of the air in a bedroom every time it fully extends each direction. It moves almost 2 inches each direction max excursion- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Oh... that'd literally damage the wall probably. The pressure under the stairs would be too high I know that for a fact. I guess this will be something that will wait until I have a house of my own in like a decade or so lol.
To be fair I still intend on getting some PSW1200s to match my RT3000p so I should be fine in the subwoofer department for now.My gear:- TCL 75QM7K TV
- RT3000p Fronts
- CS1000p Center
A Small Subwoofer Comparison! SVS SB1000 Pro vs 3000 Micro.
https://youtu.be/pADwLWlZfqQ Yamaha RX-A2070, Musical Fidelity M6si integrated amp, Benchmark Dac1, Bluesound NODE 2i, Audiolab 6000CDT CD Transport, Parasound Zphono USB Phono Preamp, Fluance RT85, Ortofon 2M Bronze, Polk L600's, L400, L900's, RC80i's, SVS 3000 Micro, Audioquest Interconnects and Digital Cables, Nordost Silver Shadow Digital Cable, Cullen Gold and Crossover Series Power Cables, Douglas Connection Alpha 12AWG OCC Speaker Cables, Douglas Connection Alpha Analog Interconnect Cables, Douglas Connection Alpha 11 OCC Custom Power Cable, Signal Power Cable, Furman PL-8C 15 Power Conditioner, Sony 65" 900F, Sony UBP-X700, Fios, Apple TV 4K, Audioquest Chocolate HDMI Cables. SnubWay, Main Stream -
Man, I really wanna try one of these things, Mike, just to see what they're like for myself. I just don't need anymore subs, do I, @rooftop59 @F1nut ? The answer is H-No.
@Tony M is my inspiration moving forward. If he can do it, I can do it!
No, you don't.
There is no such thing as not needing more subs. You ALWAYS need more subs.
Sincerely, a bass addict.My gear:- TCL 75QM7K TV
- RT3000p Fronts
- CS1000p Center
