Digital noise - magnifi mini AX
saintly_guy
My new magnifi mini AX make a weird digital noise when it moves from one sound format to another. The soundbar is connected to VU tv eARC port and media source is Apple TV 4k
Answers
When you say "moves from one sound format to another" can you explain? Do you mean encoding format? Also, can you elaborate on what the digital noise sounds like? Do you mean there's a hissing sound? Or a buzzing sound?
>>> yes …
Listen to these for the noise:
Do you mean that "crunching" sound when the video on the right screen begins playing? If so, I don't think the soundbar is causing it. It is more likely it is being caused by whatever you are using to download the program.
