Balanced Turntable connections
xsmi
xsmi Posts: 1,804
Anyone have any experience with this? How far do you have to carry the balanced connections through your chain for it to make a difference? My preamp ddoesnt have balanced connections and my power amp is a differential design if I were using the balanced connections in the amp, which would conflict with my Legends.
2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-19L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
  • Emlyn
    Emlyn Posts: 4,821
    If I have the option of using balanced cables I will but mainly because I prefer the physical design of XLR connectors over RCA and they make me feel special. In some cases a balanced cable can provide higher gain but that's entirely dependent on the equipment they're connecting rather than the cable itself.
    Generally speaking in a home environment balanced cables aren't going to produce better quality sound than unbalanced cables if they're equivalent designs. But I figure if the designer of the gear put XLR jacks on them I'm going to use them.
    audioluvr Posts: 5,986
    Could possibly eliminate ground loop hum?
  • engie490
    engie490 Posts: 444
    For a while, I ran balanced phono into an Innersound Phono then to a Rowland Synergy IIi which fed my Rowland Model 8 amp. The sound was excellent, but there was no way to compare if the balanced part made a difference because the Synergy preamp doesn't have any unbalanced connections. I'm now into tubes for the preamps (Herron VTSP-3A and Fosgate Signature Phono), which both are unbalanced only. Excellent sound again, but the subtle life that tubes bring to the sound.
    Infinity RS-1Bs / Bryston 7B STs / Sonic Frontiers Power 2 / Jeff Rowland Consonance / Bluesound Node 130 /Oppo BDP-105D / Technics SP-15 w/SAEC WE-308SX & Ortofon AS-309 arms / Audio-Technica ART-1 & Dynavector XX2 Mk II carts
  • mantis
    mantis Posts: 17,557
    At what point do Turntables have balanced connections? I have seen 12k player that still use unbalanced RCA connections.
    Dan
  • Joey_V
    Joey_V Posts: 8,603
    I think it is not necessary. None of my tables come with stock xlr connections and I have the Avenger Reference and HW40 black by VPI
  • Emlyn
    Emlyn Posts: 4,821
    Pro-Ject has been marketing turntables with balanced output cabling into a balanced phono preamp as being superior since last year. Claims are the separation of grounding produces benefits in background noise suppression.
    It's not a new concept though.
  • SeleniumFalcon
    SeleniumFalcon Posts: 4,304
    edited April 2023
    Actually, the signal generated by a phono cartridge is a balanced signal, a voltage is generated in the two coils inside the cartridge neither end grounded (except on the older Decca London series of cartridges). This is why you can reverse the polarity on the left and right pins on the cartridge and everything works fine. The trouble is the phono input treats this balanced signal as a single ended signal and ties one of the coil's wires to the circuit ground.
  • jdjohn
    jdjohn Posts: 3,381
    edited April 2023
    Phono cartridge signals (both MM and MC) are inherently 'balanced' due to the coils carrying the signal. The real limitation is in phonostage designs, since (I reckon) it is more difficult (and costly) to design a balanced INput stage.
    Phonostages with true, balanced inputs are typically much more expensive. However, there are many mid-level phonostages with balanced OUTputs.
    The big advantage to balanced connections IMO is noise/interference rejection, since the delicate phono cartridge signal is subject to RFI/EMI.
    EDIT: the grounding configuration of any particular turntable/tonearm/cartridge can also come into play here. Many times, the signal ground and earth ground are combined into one cable/connection. But in higher-end designs, the earth ground is connected to either the tonearm or the chassis, and no real signal-ground is needed. YMMV
  • xsmi
    xsmi Posts: 1,804
    Joey_V wrote: »
    https://pro-jectusa.com/product/connect-it-phono-ds-rca-mini-xlr/
  • Joey_V
    Joey_V Posts: 8,603
    xsmi wrote: »
    Joey_V wrote: »
    So that’s like a Y cable into a single xlr? The single goes to the phono?
  • xsmi
    xsmi Posts: 1,804
    Yes. And then connect the phono pre to the pre with balanced cables.
  • Joey_V
    Joey_V Posts: 8,603
    A phono can handle a single xlr? I wasn’t aware
  • Joey_V
    Joey_V Posts: 8,603
    For my 2 vpi, there’s this option instead
    I’m not sure whats to gain by adding more wire to an already sensitive phono cable connection
    https://elusivedisc.com/vpi-jmw-xlr-junction-box-with-standard-vpi-wire/
  • xsmi
    xsmi Posts: 1,804
    Joey_V wrote: »
    It looks as if it replaces the rca connections on your turntbale. Your arm would be connected to the junction box instead of where it connects to the deck now. They even have it with Nordost internal wiring.
  • xsmi
    xsmi Posts: 1,804
    edited April 2023
    Joey_V wrote: »
    xsmi wrote: »
    Joey_V wrote: »
    Yes. This is the picture of one of their balanced phono pres and I've seen others with this connection as well. I always assumed they took the connection directly off the tonearm.
  • Joey_V
    Joey_V Posts: 8,603
    I’d have to look at my arc 10 to see if it has balanced inputs
