Post a picture... any picture
1…852853855857858…1107
    Clipdat Posts: 13,105
    This is your finest work to date. Bravo sir, BRAVO.
  • maxward
    maxward Posts: 1,743
    Looking forward to Daisy’s reply!
    mhardy6647 Posts: 35,562
    I wouldn't mess with a male cardinal in mating season (which is nigh)! Ounce for ounce, they're very pugnacious.
  • sucks2beme
    sucks2beme Posts: 5,703
    They were dive bombing the cat last year.
    The lady next door with the bird feeders moved
    out. Pretty quiet out this spring. The cat rules Supreme.
    He's been presenting the Mrs with half dead mice and
    Snakes (small ones). She's NOT thrilled.
    F1nut Posts: 52,406
    edited October 20
    You see that coming you're in deep dodo.
  • Keiko
    Keiko Posts: 807
    edited October 20
    There's a Samsquatch in thar somewhere. :#
  • OleBoot
    OleBoot Posts: 3,138
    msg Posts: 10,650
    edited October 20
    Real life Angry Birds?
    Tony M Posts: 12,025
  • daddyjt
    daddyjt Posts: 3,265
    ― Aleksandr Solzhenitsyn
  • sucks2beme
    daddyjt wrote: »
    Is that a brake pad?
  • sucks2beme
    Why is there a keyboard and mouse next to the sink?
    Does the Cat surf the internet while chillin.
    msg Posts: 10,650
    daddyjt wrote: »
    Little bit past the wear indicator?
    Viking64 Posts: 7,824
    There's a little more brake dust than normal. They should have that checked. :*
    msg Posts: 10,650
    edited October 20
    Are cardinals truly aggressive? I've never seen them behave that way around here.
  • soundfreak1
    soundfreak1 Posts: 3,414
    edited April 2023
    Ya we have homicidal Mockingbirds here! Nasty f-iers, unrelenting. That is a remarkable photo though!
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • skipshot12
    skipshot12 Posts: 2,164
    edited October 20
    msg wrote: »
    Definitely looks like the Kamikaze version 😳
  • OleBoot
    From observing the behavior of the birdies coming to our feeder, the who's wary of who pecking (I crack myself up) order seems t be: Nobody bothers a woodpecker. Blue Jays are bullies who chase the smaller birds away. Cardinals share with everybody bar...blue jays - maybe they are the Robin Hoods of backyard birdies.
    Yes cardinals can be quite aggressive. Not at the level of mockingbirds nor some larger birds (e.g., goshawks) when nesting -- but male cardinals are notorious for attacking windows, mirrors and other shiny surfaces when they see their reflection & think it's a rival male. :o
    Our across-the-road neighbor (now, sadly, deceased) had damage (to the finish) done to his nearly-new F-250 pickup by the attacks of an aggressive male cardinal a couple of years ago.
    Tonight's little visitor out back when I got home from Good Friday service.
    Unruffled (viewed from inside)
    Ruffled (viewed from outside)
    F1nut Posts: 52,406
    edited October 20
    msg wrote: »
    Remind me to tell you about crazy aggressive cardinals the next time we
    talk.
    (hifihaven)
