Need help with identifying this model and ohms
CoreySansui
Best Answer
Yes, looks like an S4 with the plastic bezel removed. They were known to crack.
Here are the specs.
Stan
Main 2ch:
HT:
Other stuff:
Answers
Made in 1994 ...
Looks like the S4, no idea about specs. Try a Google search.Political Correctness'.........defined
President of Club Polk -
Thanks!
Hmm cast baskets. Could you remove a driver and post a photo or two?George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
I did before and is only marked MW7000. I believe its 4ohms. I'm going to get a different pair that are 8 ohms. My 2000x will be better I think with larger and 8 ohm speakers...
CoreySansui wrote: »I did before and is only marked MW7000. I believe its 4ohms. I'm going to get a different pair that are 8 ohms. My 2000x will be better I think with larger and 8 ohm speakers...
Always good to know the number. My interest was mainly in the physical and mechanical design aspects of the cast basket, which Polk didn't often go with afaik, seeming to prefer stamped steel even in the current Legend line.George / NJ
iFi nano iDSD DAC
iPurifier3
Pics of the cast basket would be cool. Thanks.
Geesh you have the model number get your on look on. Sure doesn't look like a cast basket to me.
https://www.ebay.com/itm/185784041751? -
Gardenstater wrote: »Hmm cast baskets. Could you remove a driver and post a photo or two?
You totally mis-read that brochure, -
Touche! The wizardry of Polk marketing lingo. As a matter of fact I did search ebay and there was nothing at the time. Must be a new listing.George / NJ
iFi nano iDSD DAC
iPurifier3
Almost got to search daily anymore. The drivers are evaporating fast, not nearly as many or as much as there was several years ago
Hard to read that brochure on a phone! Thanks for pointing out the basket is metal, bent up to get less resonance. Designed here, made in Mexico.
How does this series of speakers compare to earlier Monitor 7, 10 speakers?
Anyone do an actual listening test between them?? -
But not designed well to avoid internal sound wave reflections that can hit the back of the cone and get expressed as a lack of clarity.
George / NJ
iFi nano iDSD DAC
iPurifier3
Reflection free design. -
^^^YepGeorge / NJ
iFi nano iDSD DAC
iPurifier3
Did some searching around here and found out that the “old” Monitor 7 is a better speaker than the “S8 or 10”.
Well, that’s good since I have a pair of originals, 7A and 7B speakers!
