Need help with identifying this model and ohms
Best Answer
  • skrol
    skrol Posts: 3,474
    Answer ✓
    Yes, looks like an S4 with the plastic bezel removed. They were known to crack.
    Here are the specs.
    Stan
    Main 2ch:
    HT:
    Other stuff:
Answers
    F1nut Posts: 52,105
    Looks like the S4, no idea about specs. Try a Google search.
  • Hmm cast baskets. Could you remove a driver and post a photo or two?
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • I did before and is only marked MW7000. I believe its 4ohms. I'm going to get a different pair that are 8 ohms. My 2000x will be better I think with larger and 8 ohm speakers...
    Always good to know the number. My interest was mainly in the physical and mechanical design aspects of the cast basket, which Polk didn't often go with afaik, seeming to prefer stamped steel even in the current Legend line.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • odcics2
    odcics2 Posts: 388
    Pics of the cast basket would be cool. Thanks.
    pitdogg2 Posts: 27,489
    Geesh you have the model number get your on look on. Sure doesn't look like a cast basket to me.
    https://www.ebay.com/itm/185784041751?
    You totally mis-read that brochure,
  • pitdogg2 wrote: »
    Touche! The wizardry of Polk marketing lingo. As a matter of fact I did search ebay and there was nothing at the time. Must be a new listing.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    Almost got to search daily anymore. The drivers are evaporating fast, not nearly as many or as much as there was several years ago
  • odcics2
    odcics2 Posts: 388
    edited February 2023
    Hard to read that brochure on a phone! Thanks for pointing out the basket is metal, bent up to get less resonance. Designed here, made in Mexico.
    How does this series of speakers compare to earlier Monitor 7, 10 speakers?
    Anyone do an actual listening test between them??
  • odcics2 wrote: »
    But not designed well to avoid internal sound wave reflections that can hit the back of the cone and get expressed as a lack of clarity.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • odcics2
    odcics2 Posts: 388
    Reflection free design.
  • ^^^Yep
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • odcics2
    odcics2 Posts: 388
    Did some searching around here and found out that the “old” Monitor 7 is a better speaker than the “S8 or 10”.
    Well, that’s good since I have a pair of originals, 7A and 7B speakers!
