Monitor 11T , can anyone suggest a horn tweeter that would be compatible
Hi all, I recently got myself a pair of 11t speakers. I like the sound everall, very pleased. However, they leave me missing the sound from the horn tweeters of my Zenith Allegros. I have read about the upgrade that most do for tweeter replacement. Its not what I want.
I am wondering if anyone here would be able to suggest a good horn tweeter, possibly one that is compatible with these speakers factory setup. Has anyone reading this done such a thing to the Rt11s? Thank you for any pointers. James
Best Answers
«134
Answers
    F1nut Posts: 52,226
    You've got to be joking.
  • jamnjc3
    Not even a little. My ears love horns.
    F1nut Posts: 52,226
    Then buy speakers designed and built with horns...geesh!
    xschop Posts: 5,682
    A set of Polklipsch would be a wonderful amalgam of auditory bliss.
    mhardy6647 Posts: 35,440
    edited February 2023
    So -- @jamnjc3, as has been succinctly but emphatically pointed out, no.
    Nope. You shouldn't do it, and there exists no horn (compression) tweeter that will be an improvement to what you have.
    That said, it's your money and they're your loudspeakers, so you may do with them as you wish.
    Case in point: https://forum.polkaudio.com/discussion/195974/documenting-my-sda-1c-upgrades-from-start-to-finish/p1
    IF you really, truly want to play with horn sizzle with your 11t speakers, I'd say your guiding principle should be do no harm, which (from my perspective) would mean you could try a "supertweeter" horn. This would be a driver crossed over to your Polks at a very high frequency (10 kHz, or even more), external to the speakers.
    You'll need a horn loaded compression tweeter that has very extended high frequency response. They're rare but not unknown. You'll also need an "L-pad" (variable, at least to start the experiment) because any "true" horn tweeter (as opposed to a dome tweeter set into a "waveguide", as is currently fashionable) is MUCH more sensitive (louder!) than your Polks. Most important, you'll need a very good quality crossover (XO) capacitor. If I were trying this (not that I would) I'd use a 1 uF capacitor, which will give a nominal crossover frequency of 20,000 Hz.
    *Here's a first-order crossover calculator for first order. You only care about the "high pass" value.
    https://www.v-cap.com/speaker-crossover-calculator.php#firstOrderCalculator
    *Here's a reasonable choice for a capacitor (chosen more or less randomly).
    https://www.madisoundspeakerstore.com/claritycap-csa-capacitor-630vdc/claritycap-1.0-mfd-csa-copperconnect-poly-cap-630v/
    *Here's a good, extended, and reasonably priced tweeter to use:
    https://www.madisoundspeakerstore.com/bullet-tweeters/fostex-ft17h-horn-super-tweeter/
    *Here's an 8 ohm L-pad that will work.
    https://www.madisoundspeakerstore.com/l-pads-attenuators/yung-lp15-3/4-15w-8-ohm-l-pad/
    You'll need some wire to hook it all together, like this:
    You can buy a bag of clip leads for a couple of bucks to test this out.
    Hookup to the speaker is simple. You simply connect the two wires shown above (the "+" and "-" in the diagram) in "parallel" to the speaker. A pair of banana plugs is handy for this -- just "piggyback" to the existing connection to each speaker. The tweeter will barely change the load to the amplifier, and only pass signals at extremely high audio frequency, and not have any effect on the operation of the speaker's built-in crossover.
    This is what you'll end up with (although this is a much, much, much more expensive supertweeter, and a vintage Sprague Atom capacitor). The white box is just the box that the L-pad came in!
    You'll use the L-pad to adjust the tweeter output so that it just adds a little bit of "air" or "sparkle" to the sound.
    Now, it can be argued (and rightly so) that the 11t wouldn't need a supertweeter. That is almost certainly true. But if you really, really want to evaluate that thesis empirically, you can do so for a relatively nominal investment and without doing any irreversible damage (modifications) to the loudspeakers themselves. You can always sell the tweeters and XO components on eBAY and recoup your much of your investment if you decide the experiment was a failure.
    So, to summarize. No, we cannot suggest a compatible horn tweeter and it's a silly idea. But you can certainly give it a go if you want to. Heck, they laughed at Tesla (and for good reason!). B)
    This is the best advice.
    Here, these'll work for you:
    https://www.klipsch.com/products/heresy-iv-floorstanding-speaker
    Toolfan66 Posts: 18,320
    At this point I believe we are all being trolled around here just to see what we might say.
    Multiple accounts??
  • plastic_avatar
    That big post up there (L-pad explanation and everything) is great.
    Timely, too. These came up on FB recently:
    Other than something like an added Fostex, I haven't known anyone who tried integrating anything else.
    Sadly, matching ye olde Allegro might be a tough row to hoe.
    https://www.madisoundspeakerstore.com/super-tweeters/
    The Thrifty Setups in Mah House Big thrifty stereo in the basement w/ my custom SDA-1C (built with help from kind forum members) * Beautiful 1966 MCM GE console upgraded w/ Bluetooth, Dual turntable, and Paradigm speakers in family room * Swanky 1980 Realistic system and great TEAC eq with dancing colored lights in the living room * custom 5B on a system for my Dad * Ye Olde college stereo in the garage
  • jamnjc3
    Thank you all! Thanks especially Mhardy.
    Nobodys being Trolled. As I said I was serious. Id also say alot of you know much more about home audio speakers than me. I got these 11s because I always heard how great they are. And they are. Its simply put that I like how the Allegro tweeters sound over the ones in these rt11s. I dont understand why thats hard to understand, unless something is wrong with these tweeters, and I dont think so. My ears enjoy the horns more
    I wouldnt do anything to ruin the 11s. If I did experiment it would be in such a way that it could be reversed in the future.
    That said, after seeing these responses, I think I will take yalls advise , sell these and buy a set of those Heresy IV speakers. I am not good enuff electronicly speaking to tackle what Mhardy suggests. Though, if I had the skills I probably would try it, just to try it.
    Thanks for the comments, though not what I wanted to hear for the most part, id say your all probably right for me to just get other speakers made with horns. So thanks again yall.
    Not Ravens, but a fairly sensitive, non-horn supertweeter (JVC/Radio Shack planar tweeter), same notion as above. I used these with Altec Valencias.
  • plastic_avatar
    @mhardy6647 Did you do the pad and mount work on those?
    I built them from dump-find drivers (which is why they're a little scuffed up), yes.
    I used a couple of plastic Hammond boxes.
    ... and, yes, wired 'em with CAT5 :blush:
  • plastic_avatar
    Nice.
    Did you have to play with positioning and angle to get them to mesh with the Altecs?
    Not to hijack, but I thought about trying to add a ribbon to the top of my homebrews (Eton hexacone 8 and a 1" fabric dome). The highs are a little... dome'ish.
    I already bookmarked this because of your response up there^ =)
    It's your thread ;)
    but I'll PM you with some info.
  • jamnjc3
    Toolfan,,, how do they sound with your setup?
  • jamnjc3
    xschop Posts: 5,682
    Those are the extremely rare 11TRL's
    nooshinjohn Posts: 26,084
    Toolfan66 wrote: »
    Me so Hohney…
  • bcwsrt
    bcwsrt Posts: 2,609
    Polklipsch? More like Polkenstein. 😳
    Brian
  • jamnjc3
    Toolfan66 wrote: »
    Jesus, I just realized its photoshopped...damn it, got me all Horny and stuff! Hahaha
  • jamnjc3
    Please explain why its a silly idea. I dont understand why everyone seems to think its a crazy idea. Id just like to know why.
    Why do my old Allegro horn tweeters produce a sweeter sound than the tweeters in the 11s?
    Or is it just my ears? Thank you.
  • jamnjc3
    I had read about people swapping the tweeter for an RD-0198 tweeter. So I cant be the only one not impressed by the tweeter.
    Also, the RD-0198 is a 8ohm speaker.
    So is the Fostex that was suggested. The 11 speakers are listed as 6ohm speakers. Is 6 ohm just the mids and woofers? Thanks again.
  • jamnjc3
    Has anyone heard a RD-0198 tweeter and also heard that FT7H Fostex horn? Just curious what your ears may have thought of the comparison.
    Your crossovers are in need of attention due to age, which diminishes the performance of the speaker, and the original tweets should be replaced as well. Polk understood this and made the RD0 series tweeters to improve the sound over the SL2000/3000 tweets.
    The reason you are being advised to not use horns is that there is nothing about a Polk speaker that was ever intended or designed to be used with that type of tweeter. Literally everything about the speaker would need to be completely changed, including the MW drivers, the cabinet, and crossover design in order to do what you are trying to accomplish.
    If the horn sound is what you are chasing, go in that direction with a pair of speakers designed to do them justice instead of trying to force a square peg into a round hole.
    F1nut Posts: 52,226
    jamnjc3 wrote: »
    The 11T uses the SL2000 tweeter with its 5dB spike @ 13kHz. The proper replacement is the RD0194-1, not the RD0198-1.
    Since you like horns that SL2000 should be right up your ear bleeding alley.
    FYI, there's more to consider when changing a tweeter than the ohms rating.
  • jamnjc3
    Thanks Nushinjohn.
  • jamnjc3
    jamnjc3 wrote: »
    Thanks Nushinjohn.
    I did read about changing the crossovers and the rd tweets, also read alot of comments that people thought it made a pretty big difference. Its fairly inexpensive and easy too. I still dont think it will sound like the horns , correct, or am I wrong? Im asking, because I really dont know. Thanks
