Loud blow back sound from subwoofer
I have an older(8+ years) Polk surround sound set of speakers(7) attached to a Pioneer receiver and my Panasonic TV. We're getting periodic very loud "cracks" of sound coming from our subwoofer. The connections seem tight but I'm wondering if the cord connecting to the receiver should be replaced. Or is the problem likely to be a failing speaker?
Would appreciate any comments/advice.
    Clipdat Posts: 13,100
    The subwoofer's built-in amplifier is failing.
    txcoastal1 Posts: 13,519
    edited February 2023
    It’s passing a little gas….
    It is going to eventually shat on you
    lolol, laughed way too hard at that.
    mhardy6647 Posts: 35,232
    I was thinking of cross-referencing the "blowhole" thread when I saw this thread's title -- but that actually wouldn't have been helpful at all...
    The failing subwoofer amplifier sounds, unfortunately, like an all-too-likely culprit. :(
    F1nut Posts: 52,000
    Time to shop for a new sub. Since this appears to be for HT use might I suggest looking at SVS.
