Question regarding the old EPIK Empire sub
Hello, one of my subs blew it's second amp. Is anyone familiar with the Epik Empire and experience a similar catastrophe and know of a adequate replacement amp??
Set up: 11.2 HT + 2ch
Cables: Mogami AES from CDP to DAC - AQ McKenzie XLR from DAC to AVP to amp for 2ch, Emotiva XLR's for the rest - Douglasconnection: Furutech Alpha 36 12g speaker wire for 2ch, Furez 10g speaker wire for the rest - AQ Forest48 HDMI for the display, AQ Carbon48 HDMI from BRP to AVP - VR3 filtered power cables for CDP, BRP and AVP, Emotiva power cables for the amps - AudioQuest 707 power conditioner.
Best Answer
  • WLDock
    WLDock Posts: 3,073
    edited March 2022 Answer ✓
    Geoff4rfc wrote: »
    I had considered ZLTFUL's suggestion however that rating is at 4 ohms.
    A 4 Ohm rating is what you need right? The Empire / Legend individual drivers are 8 Ohm, combined in parallel for a 4 Ohm load. Most plate amps produce optimum power at 4 ohms.
    As far as the Sound Tower amp, it might be ok but its listed as a PA amp. That small diameter fan might be a high pitch winer.
    STPAS-800D_Class-D_700W_RMS_Plate_Amplifier-Amp_Module_864x864.jpg?v=1640129411
    Imo, from partsexpress, the Dayton, Yung, or BASH 500 watt amps would be safe bets. The ICEpower 500 watt board would be a premium option.
    The SpeakerPower SP1-700-HT (1 x 700W @ 4Ω ) ICEpower amp would be a premium option. (There are heavy hitter amps used in pro audio and high end subs from the likes of Seaton Sound)
    https://www.speakerpower.net/store/c3/Plate_Amplifiers.html
    Then there are pro amps that would work well.
Answers
    VR3 Posts: 29,497
    Just have an aluminum plate cut for the size and then use an external pro Amp
  • WLDock
    WLDock Posts: 3,073
    edited March 2022
    Some have repaired these amps. Of course it depends on how bad the damage and if one can find a reasonable tech or DIY.
    If the amps to both subs have gone bad then as others have stated, consider using a pro amp.
    Whatever you do, DON'T THROW AWAY THE AMP PLATE!
    The electronics can be either removed or left in place and disconnected from the inputs. Then, the drivers can be wired to terminals on the plate. Even if you have to replace the balanced inputs and add in speaker inputs. No need to find a plate!
  • Geoff4rfc
    Geoff4rfc Posts: 2,901
    Thanks fellas....I appreciate the imput.....I took the plate to Bjorns here in San Antonio, I have good report there since I worked there as an installer for a short bit....the amp is totally fried...unable to repair which was my greatest hope......
  • ken brydson
    ken brydson Posts: 9,011
    Geoff4rfc wrote: »
    Dude, was wondering what happened to you. Looks like you moved back to TX. Hope all is well.
  • Geoff4rfc
    Hey Ken, yes sir, took me long enough but finally made it home to San Antonio!
    EndersShadow Posts: 17,714
    Sup Bro!
  • Geoff4rfc
    Sup Bro!
    Hey Danny!!! Good to see you!
  • Geoff4rfc
    After "no mamma, the soich continues" door knock after door knock, looking at pro amps (thanks VR3) and searching Dayton (thanks ZLTFUL), I inquired about the SVS upgrade kit 13 ultra...looked good to me but SVS wouldn't sell since I wasn't truly upgrading the required SVS sub. So, this is what looks to be a viable option to resurrect the Empire.... https://www.parts-express.com/Dayton-Audio-SPA1000-1000W-Subwoofer-Plate-Amplifier-300-809?turntoflow=qco&ttdat=eyJjIjoxMDQ2NSwidSI6NTcwNjMxOCwiZiI6Ikdlb2ZmcmV5IiwibCI6IkxhbWJlcnQiLCJtIjpmYWxzZX0&tttok=eyJhbGciOiJIUzI1NiJ9.eyJpc3MiOiJUdXJuVG8iLCJleHAiOjE2NDg0Nzg3NDEsInUiOjU3MDYzMTgsInMiOiJVU0VSX0NPTkZJUk1FRCJ9.xqjXvfOYNYBHfFmicE8ZStWLAG6hL7aWB6Vun1rEMYY&turntosku=300-809 the SPA 1000
  • Geoff4rfc
    Sorry to be a bother however, I value the input of the veteran members here so, along with the SPA1000 (linked above) is a class A/B. the OEM is a class D. I have found this one as well, https://www.amazon.com/Sound-Town-Speakers-Subwoofer-High-Pass/dp/B08G6ZHMPK/ref=asc_df_B09KVLJ8RY?tag=bingshoppinga-20&linkCode=df0&hvadid=80127036358517&hvnetw=o&hvqmt=e&hvbmt=be&hvdev=c&hvlocint=&hvlocphy=&hvtargid=pla-4583726556651092&th=1 which is a class D and is rated higher than the A/B amp and would be closer rated to the OEM amp. I had considered ZLTFUL's suggestion however that rating is at 4 ohms.
    Thank you, gentleman, once again.
  • aprazer402
    aprazer402 Posts: 3,400
    @Geoff4rfc Let us know how the replacement amp works. I have an Empire brand new still in it's delivery carton never unboxed. I bought when they were first announced. Haven't set up a HT yet. I also have a Polk PSW-505 in it's box, never opened either. I guess I made a couple of poor choices. :/
  • Geoff4rfc
    Howdy, just thought I'd drop a note and make mention of the replacement amp for the EPIK Empire. Using the SPA500 and by golly, it's been kicking ever since. Sure is nice to be able to run both subs again. Thanks again for the recommendations.
    pitdogg2 Posts: 27,169
    Thanks for the update brah!
  • Geoff4rfc
    Absolutely!!! It was awesome for the folks here to chime in with the suggestions. I had the Empires stacked for a bit and now have one placed behind the seats between the RTiA9 rear surrounds. Two sets of RTiA9s as wides and rears, the 703s at surround, the 707's and 706 on the front...all set to large, two Epik Empires...I've got some "decent" LFE lol
  • ken brydson
    Geoff4rfc wrote: »
    Yeah, your system sounded pretty weak without subs when I visited 🤣
  • JayCee
    JayCee Posts: 1,509
    @Geoff4rfc Thanks for the follow-up....glad to see the SPA500 works. I have an Empire that I purchased new around 2011. So far, my amp hasn't given up the ghost. Several years ago it would get finicky when I cycled it off/on but found if I just left it in auto detect mode there were no issues. Honestly, I expected it to go by now. I've read several threads around the net but didn't "know" anyone w/success replacing the amp. Again, thanks for the update and I've bookmarked this thread in case I need to hit you up for help.
    Cheers,
    John
    Speakers: Polk1.2tl's (Uber Mods) Pre/Amp/DAC: PS Audio PMG Signature Pre, BHK Signature 250, PMG Signature 512 Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" Power Conditioner: PS Audio P15 Power Plant Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬
  • Geoff4rfc
    Geoff4rfc wrote: »
    Lol....yes sir Ken, you did appear pretty disappointed....KNOT lol, I loved the way you were digging the Styx CD, dude, you should take a seat over here now.....maybe not, I won't be able to get you to go home.... :D
  • Geoff4rfc
    JayCee wrote: »
    Cheers,
    John
    JayCee, appreciate the kind words. Both of my Empires gave up their original amps. Chad was great at sending out replacements. My first sub is still kicking on it's replacement. My second sub however took a crap in the first month I owned it. The replacement just went toast here earlier this year. The second replacement is doing just fine. The Dayton is more powerful than the OEM.
  • Geoff4rfc
    So here's a little piece of to catch up on the neighborhood gossip......yesterday, my next door neighbor comes over and rings the doorbell, when I open the door, she says, Hi neighbor, you rocking out??? Long story long....after confronting her husband weeks earlier asking if they could hear or were disturbed by my set up, he says no, and I say, cause man, I've got it cranked some times, he still says no and I'm thinking, SWEET, turn it up!!!
    Now, it's not the sound they hear, but according to his wife, their bedroom window faces my living room window albeit about 25' between them, she reports that the window frame is rattling as if a small earthquake is happening right here in good ol San Anotone....now that's some LFE by golly.
    I invited her in to take a look and right off, she was impressed with "size" of everything, . and she says, well, lets hear it. I had Man of Steel in, that was the culprit that brought her over, so I pick out a couple of demo scenes for her.....at first she says, "it's like a theater"........then after a bit of review she says, it's better than a theater. The first scene I brought up was the fishing boat on it's way to the offshore oil rig and the boat crashes through a wave and punches her right in the chest and she "exclaims" WOW, I can feel it in my chest......lol, yes ma'am.
    Now long story short, he's too polite to say anything, she's cool with it as long as I stay out of their bedroom after 9pm.
    These poor folks, they're a young couple with two boys pre jr high school age. On the other side of them is a Vato, Tim is cool enough but his car is equipped with a sub that sounds like the body is for real
    coming off the chassis and will do a victory lap at the top of the cul-de-sac before parking his car...the dishes in my cabinet dance when he does that lol.
    So there you are, all caught up.
  • rooftop59
    rooftop59 Posts: 8,120
    That’s awesome that she’s cool with it within reasonable limits! That’s about all you can ask.
    I live in a nice Texas suburb with massive houses and big yards built for, ya know, families, and my older empty-nester neighbors complain endlessly about my boxer barking. I told them we keep inside at night except when we go out but they don’t care and reported us to the cops and now we have to keep the poor dog in basically all the darn time….at least she’s older and sleeps a lol lol…
    Keep rocking on man!
    Game Room 5.1.4:
    Bedroom 2.1
  • Geoff4rfc
    rooftop59 wrote: »
    Uggg, some neighbors just need to complain. too bad about your boxer, calling the cops over something like that is kinda low. Ever consider a bark collar for the girl, let her have her domain back? Then tell your neighbors to "have a nice day"
  • pcmike
    pcmike Posts: 1
    Geoff4rfc wrote: »
    Just found this thread with some googling as the amp in my Epic Dragon finally gave up the ghost after 13 years. Was the SPA500 a drop in replacement for your empire or did you have to mod the enclosure? From what I read over on AVSforum and the dimensions of the SPA500 on parts express it seems like the SPA500 is larger than the original amp.
    Also, this may be a long shot.. but does anyone know if the Empire and Dragon used the same amp and therefore have the same cutout/etc dimensions?
  • Geoff4rfc
    pcmike wrote: »
    Was the SPA500 a drop in replacement ?
    No sir. The sub cabinet was too small for the amp to fit, so, I just wired it and placed the amp on to of the cabinet.bzzr0c0j7h9z.jpg
