Polk LSiM 703 or R900 for Height Speakers 7.2.4
See signature for media room theater equipment. I'm torn which direction to go. I read LSiM 703 are heavy and a PITA to wall mount. Atmos/DTS-X/Auro-3D.
- Living Room Music-2.0 Polk Legend L800 | McIntosh C70 | McIntosh MA5200 (Treble) | McIntosh MC452 (Bass) | Sublimeacoustic K231 Active xover | Denon DP-2500A | Denafrips Ares II | Belkin Soundform Connect | iPad Air USB to DAC
- Media Room Ht-7.2.6/13.1 (Atmos/Auro-3D) Polk LSiM707, LSiM706c, LSiM702 F/X [x4], height LSiM703 [x6], HSU VTF-15H MK2 Dual | Marantz AV8805A | Rotel RB-1590 (L/R) | Appollon NC500 11ch | Sony UBP-X800 | AppleTV 4K | JVC RS2100 | 150” Elite Screen Acoustic Pro UHD
- Game Room-5.1 Polk LSi25, LSiC, LSiF/X | Marantz SR7009 | AppleTV 4K | Xbox One S | Sony PS2, PS3 | Nintendo Wii | Gaming PC | Sony 75" LCD
- Master Bedroom Music-2.0 Totem Hawk | Marantz PM-10 | Marantz SA-10 | SONY PS-HX500
- Office-2.0 Ascend Acoustics Sierra LX, DSW microPRO3000 | Rotel RA-1570 | Marantz HD-CD1
- Daughter's Bedroom 1-2.0 TBD Martin Logan Forte | Roku TV
- Guest Room 2-2.0 Klipsch RP-600M | Martin Logan Forte
- Guest Room 3-3.0 Martin Logan Motion 40, 50XT | Onkyo TX-SR705 | Apple TV | Samsung 55" TV
- Guest Room 4-2.0 QAcoustics 3030i | Sansui AU-6900 | Topping DX7s | Sansui FR-1080 | Fire TV
- Maintenance: Pro-Ject VC-S Record Cleaning Machine
Polk LSiM 703 or R900 for Height Speakers 7.2.4 7 votes
LSiM 703 two pairsbreaking it in
LSiM 703 two pairsTemporary PM-10 for 2.0 setup with airplay
LSiM 703 two pairsSlowly getting stuff in place.
R900 two pairsMighty impressive looking!
Only suggestion/question is would the rear speakers perform better if they're even with the rear heights? Meaning, away from the side walls about a foot or two?
My guess there's a good reason you put them where they are. -
LSiM 703 two pairsHi Emelyn,
Thanks. Per polk manual it’s the recommended orientation, the mid and tweeter drivers are side firing so with them at the far corners the drivers are firing into the MLP. The directivity would be affected if I moved them close into the room, as surround backs I think the 703 would be better suited. I don’t have amps yet (was ordered and in production) so listening demos will have to wait a bit till I would know.
R900 two pairsMakes good sense. I'd forgotten the driver configuration on those was like that with essentially no sound coming out one side of the cabinet.
I was also thinking a pair of 703s could serve well as rear surrounds. I've had both models in that position and preferred the 703s but they were close and I have another pair of 703s as side surrounds. I figure it's best to have all four the same model in those positions.
I think you'll be extremely impressed with those front and rear height speakers for Atmos. -
Looks great!
That's a small space for all those speakers.Political Correctness'.........defined
President of Club Polk -
I'm wondering if its a dedicated built space with Green Glue between drywall layers or made with factory damped Gypsum? I can't tell the lengths but it looks to be about 12 ft. wide. The 7.2.4 sides are a little close to the rears. No doubt a 5.2.4 would have been more than fine.
That system is going to light that space up! (and maybe the house?) Should be able to get some good pressurization going on. It should be a very intimate experience! Should be fun!2.2 Office Setup | LG 29UB55 21:9 UltraWide | HP Probook 630 G8 | Dell Latitude | Cabasse Stream Amp 100 | Boston Acoustics VS 240 | AUDIORAX Desk Stands | Mirage Omni S8 sub1 | Mirage Omni S8 Sub2 -
LSiM 703 two pairs12.5W x 20L x 10H
Unfortunately the walls are not green glued or dampened, I will need to put up more acoustic treatments. I tested the heights running full range and the cabinet vibration travels through the speaker mount into the studs. Hopefully not an issue when crossed over at 80hz.
Two rows of 3 chairs are coming in this Wednesday.
what type/brand mounts are those that you are using for the 703's?
I was gona ask the same question.. attaching a mount to the plastic like that.. it held up? Heavy speaker.. if so I'd like to know what mount you used cause I'm debating having mine as height channels.
Full 5 channel set of Polk Audio
Fronts - LSiM 705
Center - LSiM 706c
Sides - LSiM 703
Mits WD-82842 82" DLP 3DTV
Denon AVR-3313CI Receiver
Emotiva stealth DC-1
Emotiva XPA-2/Fronts XPA-3 Center-surrounds
Oppo 103
Loving the new Family! -
LSiM 703 two pairsThe mount's are screwed through the plastic down to the wood. I've had no issues with them hanging up almost 2 years now. I was thinking of upgrading the attachment with T-nuts on the inside and switching to machine screws with standoffs.
Well, I think it's probably time for some finished pics.....you had me at "two rows of 3...". And maybe a rundown of your finished theater.....and your thoughts on it's performance since completion.Source: BRP Panasonic UB9000, CDP Emotiva ERC3 - Display: LG OLED EVO 83 C3 - Pre/Pro: Marantz 8802A - Amplification: Emotiva XPA-DR3, XPA-2 x 2, XPA-6, Speakers, Mains/2ch-Focal Kanta No2's, C-LSiM706, S-702F/X, RS-RTiA9's, WS-RTiA9's, FH-RTiA3's, Subs - Epik Empire x 2
Cables: AudioQuest McKenzie XLR's/CDP/Amp, Carbon 48/BRP, Forest 48/Display
