New vs old processor
My integra 80.2.is starting to have hdmi issues. I have a 3.1 system, and all video is run-through my oled. I have a sharc to process earc. What would be my best options for movie sound quality? I have an anthem pre 2l with ht bypass handling my music. What about an older anthem statement d2v? Any better options below $1k?
ChrisPreamp: Anthem Pre 2L (Jan-Phillips Green) Processor: Integra DHC 80.2Amp: B&K 200.5Streaming: Bluesound Node 2IDAC: Eastern Electric Minimax Plus4K Bluray: Panasonic UB820Mains: Von Schweikert VR2Center: Von Schweikert LCR15Analysis Plus Cables
  • dagame27
    dagame27 Posts: 561
    Elaborating...would either an older Anthem D2v or Marantz 8801 or newer match or better my Anthem pre2l? Or is a separate 2 channel preamp still king?
  • invalid
    invalid Posts: 1,278
    A separate two channel preamp is still best for music
  • rooftop59
    rooftop59 Posts: 7,981
    dagame27 wrote: »
    What speakers are you running? Can you really hear a difference with atmos on 3.1? In other words, must the avr have earc? Because that the really drives up the price…
    Game Room 5.1.4:
    Bedroom 2.1
  • dagame27
    dagame27 Posts: 561
    Von schweikert vr2 and lcr15 center. My integra decodes true hd and dts hd...but is showing signs of hdmi issues
  • dagame27
    dagame27 Posts: 561
    I definitely hear a difference between the lossless 4k bluray/bluray formats and loss dd+
  • dagame27
    dagame27 Posts: 561
    Also, I have a sharc to help with earc...so do not need
  • Emlyn
    Emlyn Posts: 4,372
    A Marantz AV7702 or AV7703 should be in the thousand dollar or less price range. The main "upgrade" in the last four years or so has been in video processing up to 8K and built in streaming support. The HDMI version in the processor has to fully support 4K video processing but that shouldn't be an issue and the basics of audio processing hasn't really changed for quite a few years now.
    Another option is to find a receiver since the system isn't 9.x.x and the Anthem Pre-2L doesn't need balanced connections that a processor tends to have and cost more for. I would recommend a processor though.
  • dagame27
    dagame27 Posts: 561
    I went impulse buy...which I rarely do. I got a good price on a sr7012 receiver. We'll try the old avr as a pre pro...and perhaps use the additional amplifier channels for something else
