Yet another in wall speaker cable thread
verb
verb Posts: 10,176
Drywall is coming up soon in the sunroom so I'm getting ready to install the HT speaker setup.
Looking for suggestions on some decent in wall speaker cables - I have a 9.1 system with a wireless sub.
Looking at the Polk in wall 265RT or 265LS for the mains/surround, 255cRT center channel. SVS wireless sub.
Some of the basics that come to mind - quality conductor, 12-14ga, shielded, in wall rated
Some that I've looked at so far:
Audioquest X2
Douglass Connection (furez brand)
Canare 4S11
Crutchfield brand
Monoprice brand
Any suggestions or experiences would be greatly appreciated!
Post edited by verb on
    pitdogg2 Posts: 27,038
    Hopefully you're pulling it through PVC.
    txcoastal1 Posts: 13,512
    Contractors should use the blue smurf tube or orange carlon innerduct
    Canare 4S1
  • verb
    verb Posts: 10,176
    As in PVC conduit? The wires will be inside of the insulation layer, so low risk for exposure to elements.
    verb wrote: »
    edited November 2022
    verb wrote: »
    Some sort of conduit, so down the road you can easily change up if the desire comes up. Rons stuff or something large enough to pull new stuff through easily. Look Dave we know you well enough to know that you're going to change up tomorrow and then probably change up next week and then probably change up again next year so make it easy on yourself
    And by the way you mean Canare 4s11
  • verb
    verb Posts: 10,176
    verb wrote: »
    Ugh yeah! Fixed it. Never thought of the smurf tube, but was looking at a jacketed cable. Never hurts to have another layer of protection! And yes I did think about if ever a cable fails, how would I fix it without tearing it all up!
    VR3 Posts: 29,427
    I run supra rondo in mine.... Goi g on 5 or 6 years and works perfect
    VR3 Posts: 29,427
    Side note, most receivers are common ground so a 4 conductor wire can run 3 speakers, fwiw
    Now you're cooking with gas in that big brain of yours 😉
    Maybe you want a new HDMI cable or something to go to your new projector,
    Come on Dave think big brah
  • verb
    verb Posts: 10,176
    HDMI will be a short run behind the TV and down to the HT receiver, but yes, accessibility is the key!
  • verb
    verb Posts: 10,176
    VR3 wrote: »
    What speakers are you running?
    I see a projector on the ceiling and a nice big 120" screen on the wall
    Just messing wit ya
    If you're on a budget you don't need the flex tube, but if you have thefunds, as tech changes or if you have an issue it's nice to have the flex tube.
    if you do the tube, please inspect before drywall that none have been creased...otherwise it's worthless
    16/4 with work fine, 14/4 would be the premium for any upgrades or even room changes
    Document and file for future resale
  • verb
    verb Posts: 10,176
    Just messing wit ya
    I wish. I'm lucky to get in wall speakers, as this room is my wife's dream. I got the garage, she gets the sun room. We negotiated a flat screen, with in walls, and a small cabinet for the receiver!
  • verb
    verb Posts: 10,176
    txcoastal1 wrote: »
    Great advice!
    VR3 Posts: 29,427
    I run the definitive uiw series, in ceiling with fi audio infinite baffle subs
  • skipshot12
    skipshot12 Posts: 1,957
    What he’s saying…..
    And if in the future you want to upgrade or try something else.
  • verb
    verb Posts: 10,176
    Thanks everyone who advised me on this project! I decided to go with Supra Classic 2.5 (bought 200ft) and flexible conduit throughout. I like this stuff because it's tinned throughout, 13ga OFC, and of course the price was great (~ $1/foot).
    From Madisound website:
  • verb
    verb Posts: 10,176
    I upgraded the PVC conduit from smurf tube to a "water tight" grade, not because I want it water proof, but with the extra layer of molded PVC over the corrugated layer, it makes the conduit a lot stiffer, and IMO less prone to collapsing/creasing along the way. Especially if you happen to run new wires through it in the future. More expensive than smurf tube, but this will be, IMO a lot more robust.
    VR3 Posts: 29,427
    Nice!
    Should work great!
    Nice! Agree that should work wonderfully.
    Remember the pull string for any future wire pulling. 😉
  • gp4jesus
    gp4jesus Posts: 2,019
    @verb: what's the conduit’s ID?
    Please only answers to the “in-wall” question.
    for 2-3 years from now to anyone: if I follow verb’s water proof example (in outside walls), MUST I still use “in-wall rated” wire*? Specifically 50’ long balanced ICs* to feed remote amps to power surrounds?
    TIA. Tony
    *all connected w/Premiere ICs
  • verb
    verb Posts: 10,176
    gp4jesus wrote: »
    TIA. Tony
    I chose to go with the 1" ID
  • I tried Googling this and didn't find a satisfying answer: "a 4 conductor wire can run 3 speakers, fwiw". How does this work? @VR3
  • verb
    verb Posts: 10,176
    HzTweaker wrote: »
    IIRC they can share a common negative conductor? I decided to go with a separate run (2 conductor) each anyways, to make it easy to replace if need be, with a separate conduit line for each.
    VR3 Posts: 29,427
    On my rx3070 all of the grounds are common so when I ran the front left and right I simply used a single ground wire for all three speakers and jumped between the speakers. Has worked perfectly for years
    VR3 Posts: 29,427
    The downside to that is If I wanted a separate amp I would need a 3 Channel common ground amp
  • verb
    verb Posts: 10,176
    verb wrote: »
    gp4jesus wrote: »
    TIA. Tony
    Lol yeah I'm losing it.
    Correction - I went with the 3/4" nominal ID, of which now I felt compelled to measure! It's actually 13/16" ID, and 1-1/16" OD. Southwire brand from the Depot.
