Yet another in wall speaker cable thread
verb
Drywall is coming up soon in the sunroom so I'm getting ready to install the HT speaker setup.
Looking for suggestions on some decent in wall speaker cables - I have a 9.1 system with a wireless sub.
Looking at the Polk in wall 265RT or 265LS for the mains/surround, 255cRT center channel. SVS wireless sub.
Some of the basics that come to mind - quality conductor, 12-14ga, shielded, in wall rated
Some that I've looked at so far:
Audioquest X2
Douglass Connection (furez brand)
Canare 4S11
Crutchfield brand
Monoprice brand
Any suggestions or experiences would be greatly appreciated!
Audioquest X2
Canare 4S11
Crutchfield brand
Monoprice brand
Post edited by verb on
Hopefully you're pulling it through PVC.
Contractors should use the blue smurf tube or orange carlon innerduct
Canare 4S1
As in PVC conduit? The wires will be inside of the insulation layer, so low risk for exposure to elements.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Some sort of conduit, so down the road you can easily change up if the desire comes up. Rons stuff or something large enough to pull new stuff through easily. Look Dave we know you well enough to know that you're going to change up tomorrow and then probably change up next week and then probably change up again next year so make it easy on yourself
And by the way you mean Canare 4s11 -
Ugh yeah! Fixed it. Never thought of the smurf tube, but was looking at a jacketed cable. Never hurts to have another layer of protection! And yes I did think about if ever a cable fails, how would I fix it without tearing it all up!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
I run supra rondo in mine.... Goi g on 5 or 6 years and works perfect- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Side note, most receivers are common ground so a 4 conductor wire can run 3 speakers, fwiw- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Now you're cooking with gas in that big brain of yours 😉
Maybe you want a new HDMI cable or something to go to your new projector,
Come on Dave think big brah
HDMI will be a short run behind the TV and down to the HT receiver, but yes, accessibility is the key!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
What speakers are you running?Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
I see a projector on the ceiling and a nice big 120" screen on the wall
Just messing wit ya -
If you're on a budget you don't need the flex tube, but if you have thefunds, as tech changes or if you have an issue it's nice to have the flex tube.
if you do the tube, please inspect before drywall that none have been creased...otherwise it's worthless
16/4 with work fine, 14/4 would be the premium for any upgrades or even room changes
Document and file for future resale2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Just messing wit ya
I wish. I'm lucky to get in wall speakers, as this room is my wife's dream. I got the garage, she gets the sun room. We negotiated a flat screen, with in walls, and a small cabinet for the receiver!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
txcoastal1 wrote: »If you're on a budget you don't need the flex tube, but if you have thefunds, as tech changes or if you have an issue it's nice to have the flex tube.
Great advice!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
I run the definitive uiw series, in ceiling with fi audio infinite baffle subs- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
What he’s saying…..
And if in the future you want to upgrade or try something else.
Thanks everyone who advised me on this project! I decided to go with Supra Classic 2.5 (bought 200ft) and flexible conduit throughout. I like this stuff because it's tinned throughout, 13ga OFC, and of course the price was great (~ $1/foot).
From Madisound website:
I upgraded the PVC conduit from smurf tube to a "water tight" grade, not because I want it water proof, but with the extra layer of molded PVC over the corrugated layer, it makes the conduit a lot stiffer, and IMO less prone to collapsing/creasing along the way. Especially if you happen to run new wires through it in the future. More expensive than smurf tube, but this will be, IMO a lot more robust.
Nice!
Should work great!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Nice! Agree that should work wonderfully.
Remember the pull string for any future wire pulling. 😉 -
@verb: what's the conduit’s ID?
Please only answers to the “in-wall” question.
for 2-3 years from now to anyone: if I follow verb’s water proof example (in outside walls), MUST I still use “in-wall rated” wire*? Specifically 50’ long balanced ICs* to feed remote amps to power surrounds?
TIA. TonySamsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
*all connected w/Premiere ICs
4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s -
TIA. Tony
I chose to go with the 1" IDBasement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
I tried Googling this and didn't find a satisfying answer: "a 4 conductor wire can run 3 speakers, fwiw". How does this work? @VR32ch rig: Speakers: Magnepan LRS w/Magna Riser stands Preamplifier: Parasound P5 DAC: Fiio K13 Amplifier: Parasound A23 CDP: Pioneer DV-563A Cables: Wireworld Equinox 7 XLR ICs, Wireworld Ultraviolet 7 USB, AudioQuest Q2s, AudioQuest NRG X(preamp)
Standby: LSi9s with VR3's Fortress mods -
IIRC they can share a common negative conductor? I decided to go with a separate run (2 conductor) each anyways, to make it easy to replace if need be, with a separate conduit line for each.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
On my rx3070 all of the grounds are common so when I ran the front left and right I simply used a single ground wire for all three speakers and jumped between the speakers. Has worked perfectly for years- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
The downside to that is If I wanted a separate amp I would need a 3 Channel common ground amp- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
TIA. Tony
Lol yeah I'm losing it.
Correction - I went with the 3/4" nominal ID, of which now I felt compelled to measure! It's actually 13/16" ID, and 1-1/16" OD. Southwire brand from the Depot.
