Tri-Vista & Audioquest Thunderbird
I have made a few changes in my rig over the past few months. 1st. Doing this on my cell so excuse misspelled things.
I replaced the T+A Integrated for a Tri-Vista. Now, off the bat, I am not saying one is better then the other since they both have some amazing qualities to them and are built wonderfully but, on my 6' tall 200 lb. Tyler Highland H2, they seem to do better with the higher current and more power of the Tri-Vista.
Bass is close but, with the Tri-Vista, it allowed a bit more on the bottom end.
Width and depth, the Tri-Vista again seemed a bit more wider and deeper. It opened the Tyler's up a bit. Also a but more up front. The soundstage seem to move up a couple of rows.
Clarity is a very close tie. Both Integrateds pull a lot of detail out of the music. I listen for things in the background like Elton John Leavon, the piano in the beginning, you can hear him hit the foot pedal clearly or in Dave Brubeck take 5 you can hear them moving around in the back.
Top end, the Tri-Vista seem to have a hair more sizle on top. Not harsh or a anything but a bit more open.
I would still recommend the T+A integrated to anyone but, if you have 200lb multi driver speakers that even though at 4 ohm rating look efficient on paper, the extra current from the Tri-Vista just seems to be a better match with the Tyler's. Not gonna lie, I will miss the Loudness button and bass and treble controls on the T+A for poorly mastered album.
I then changed my RCA from High Fidelity Reveal to Wireworld Thunderbird. After they were broken in, there was just more of everything. More detail, more bass, mid, top, even deeper soundstage but, the tonality also improved quite a bit. Even though it was more of everything, it was very balanced and excellent tone to them. It took about 100 hour mark for me for the Tbird to come into their own. Wile it sounds like a long time, the Reveal was 350+++hours.
Wireworld Eclipse Silver 8 speaker cables that I thought were amazing got replaced with the AudioQuest thunderbird zero speaker cables. To me, retail on both are the same so the playing field is the same. I was not expecting the difference to be that noticeable but OMG it was.
I had to redo my subwoofer settings! Same as the RCA, more of everything but, still balanced. There was also an uptick in volume on the RCA'S and again on the speaker cables hence I had to change my Rythmik sub settings.
Thanks to all who helped push me over the edge on buying this stuff. Skip was a big part of the change but @tratliff was the other one who pushed me over the edge.
Coming soon to replace the PS Audio detect and 9 foot Cullen Crossover II ( great power cord for the $ btw)
Audioquest Niagara 5000. I heard the difference at skips the other weekend and again, shocked at the difference with that in and out of the rig.
Other parts of the system, tp-link deco 6e using a SBOOSTER power supy, EtherREGEN using a TeraDak power supply, Innuos Zen, Wireworld Platinum Usb, w4s recovery, Boarder Patrol se-i. Also the umbilical on the tri-vista was replacing with RAL( thanks F1) and using a Cullen Crossover II power cord on it. The difference on the Crossover II and the stock power cord was night and day especiallyon the bottom end and midrange. Same with the RAL umbilical cords. Just when I think the rig can't get any better, Boom a cable change or tweek change makes a big difference. All changes were done one at a time so I could hear the difference. When I put the old cables back in, I could immediately hear the difference.
Going to be trying out a RAL usb cable soon as it shipps as well as RAL Ethernet cable.
    pitdogg2 Posts: 24,609
    That Wireworld Thunderbird must be a very rare bird......
  • tratliff
    tratliff Posts: 1,671
    Sounds like you are making great progress. The Niagara will be a nice addition.
    What power cable did you decide on?
    2 Channel Rosso Fiorentino Volterra II, 2 REL Carbon Limited, Norma Revo IPA-140B, Lumin U2 Mini, VPI Prime w/SoundSmith Zephyr MIMC, Modwright PH 150, Denon DP-59l w/Denon DL-301MKII, WAY Silver 3 Ana+ Speaker Cables, WAY Silver 4+ Interconnect Cables, AudioQuest Niagara 7000 w/Dragon and Hurricane Power Cables
  • tratliff
    And I forgot. You are welcome with helping spend your money. 😀
  • erniejade
    erniejade Posts: 6,315
    LOL. Wireworld Eclipse Silver 8. AQ is the tbird.
  • erniejade
    tratliff wrote: »
    I left it is skips hands. I will find out Tuesday. :)
    EndersShadow Posts: 17,542
    As a FYI, Cullen Cable merged with Wyred4Sound and now sells his cables exclusively through their site under their name (and at a higher price than what I remember but that could just be inflation rearing it’s head).
  • erniejade
    tratliff wrote: »
    Thunder is what came.
    tonyb Posts: 32,906
    Nice Brian, you've made leaps and bounds in the last few years. Awesome..
  • erniejade
  • erniejade
    The Niagara 5000 and Thunder power cord is in. The construction on the power cables are impressive. This weekend I will redo the rack to accommodate the Niagara.
  • tratliff
    You are in for a treat.
  • tratliff
    Did you get a new power cable for the tri-vista?
  • tratliff
    Well, how is it sounding?
  • erniejade
    Darker background, more music, clear sound. It has made quite a bit of a difference. You don't realize how much floor noise you think you don't have until you get a device like this. If I had a dedicated line, I don't know if the difference would have been as dramatic as it was but, after about 3 hours on it, I replugged in the Detect and re-listened to an album. It was not just my imagination. The wife heard the difference. She even said there is just more of everything while still keeping it all in balance. I have been listening to it all day while smoking some meat. I would totally recommend the Niagara 5000 to anybody in the market in this price range. I have kept it on all weekend so I know its not fully burned in. I don't think it could sound any better with more time on it but from what I have read on both the Thunder and the 5000, they will improve even more.
    On the Tri-Vista, I am currently using a Cullen Crossover II and RAL umbilical cords. Also using a Crossover II on the Innuos zen as well. Might be time to change them out as well. The Cullen Crossover II is still a great cable btw but, while I am at it, I might as well go full loom.
    treitz3 Posts: 18,374
    It's amazing what one can hear when they no longer hear what they heard before.
  • erniejade
    treitz3 wrote: »
    That is for sure. Listening to The 1975 Human Too, the voices that came out in the beginning of the song, I originally thought it was my neighbors being loud until the music kicked in. I actually paused it and played it back.
  • tratliff
    Sounds like what I found also.
    I recently purchased Roger Waters Amused to Death from AP on vinyl. Give it a listen.
  • PSOVLSK
    PSOVLSK Posts: 5,081
    tratliff wrote: »
    I can’t imagine that on systems like you guys have. It’s fantastic on my system.
  • tratliff
    PSOVLSK wrote: »
    tratliff wrote: »
    Stop on by. You are welcome to listen!
  • GlennDog
    GlennDog Posts: 3,093
    erniejade wrote: »
    treitz3 wrote: »
    Dig that when it happens ... and thankfully it’s happening mo’ often 🥳
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • erniejade
    https://youtube.com/watch?v=TjYJaIvqToo
    This video is for the 1200. At skips, he did do a comparison between the 1200 and the 3000 and everyone in the room heard a difference. The leap between the 1200 and the 5000 is huge but yes, you pay a bit more for it but, if your system is revealing enough, you will hear a difference.
    What sub or subs are you using?
  • erniejade
    treitz3 wrote: »
    Me? Rrythmik F12 Closest sound I could find to my old Velodyne spl1200. Sharp, fast, quick, not sloppy and can hit hard.
    Clipdat Posts: 12,619
    Congrats on your Niagara 5k Brian!
  • erniejade
    tratliff wrote: »
    Listed to it on Qobuz. They have a high res version. I forgot how good that album was. Besides the basson it, man the voices come out of the woodwork on that one.
  • erniejade
    The wife and I were doing our normal Saturday AM coffee and music. She made me stop the album we were listening to 6 times because she thought someone was talking outside and heard noises that she thought were coming from outside on Rufus Wainwright Poses album. She definitely hears the difference on things.
    Sorry, I am still excited and enjoying the heck out of this rig. On a side note
    The Beatles covers and other music on here sounds freaking awesome.
