Nice wood
VR3
Future projects await!
Thanks but I hardly know you.
Nice! I was just going to add it's exciting when you first rub oil on it to see what happens with the grain patterns.
Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
I do enjoy rubbing oil on my wood
I dig that grain pattern! What species?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Sounds like a good name for a housing development- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
"Morning Woods" sounds better for a housing development, but the idea of more than one at any given time is worrisome.
Looks like crotch aka flame mahogany.Political Correctness'.........defined
President of Club Polk -
Trey likes rubbing oil on his crotch? I knew it!
Close, crotch walnut. From Aaron's @ALL212 dad's tree farm. Hand rubbed, Tung oil. I love the different appearance throughout the day as lighting changes. I was nervous about it splitting routing between the corners of the base, but it held together.
I have a matching crotch walnut turntable plinth I need to finish for the Lenco idler drive. It will be stuffed with layers of Baltic Birch. It will be a PTP build, bearing and motor plate separate.
SCompRacer wrote: »
Those are beautiful Bottlehead bases. Would love to do that for my Paramounts. -
Nice grain and color. If your wife is anything like mine, you shouldn't leave that block near the fireplace or chiminea.Don't take experimental gene therapies from known eugenicists.
His fireplace was dismantled and now houses all of his audio gear. No worries about that happening.
Whatcha gonna make, external xover boxes?Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
Will be broke down into 5 panels for substrates- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
